R32 RB25 drift project
Thread in 'Project Cars and Builds Threads' started by AnthDay, Jun 13, 2013.
  1. AnthDay
    AnthDay Member
    Hi everyone, after selling my 180sx iv just picked this up for my new drift project.
    its a 1992 r32 gtst with a rb25 conversion
    GTR intercooler
    Apexi intake
    Alloy Rad
    Full exhaust system
    Decat
    Screamer elbow
    stainless manifold
    Lots of upgraded silicone hoses
    Kaaz 2-way diff
    Gab coilovers
    Grooved front discs posh pads
    DW GTR front tension rods
    Refurbished non-hicas rear subframe
    DW poly subframe bushes
    DW camber arms
    Full Satin Black re-spray done to a high standard
    GTR front bumper and Bonnet
    20mm wider vented front wings
    GTR style rear overfenders
    Type M side skirts
    6 point weld in cage through dash.
    R33 GTR Passenger seat
    Recaro Drivers (although I would like to keep this) May be able to find replacement bucket.
    R33 clocks, stalks
    Battery relocated in boot
    Nismo gear knob
    [​IMG][/URL]
    the car has had a full r33 rb25 conversion, spec 2 rb25??
    [​IMG][/URL]
    r33 clocks and stalks have been put in the car so im assuming its the full r33 loom
    [​IMG][/URL]
    The car has had a full weld in cage fitted with only half of it painted so i will get round of stripping the car down pull the windows out and get it painted properly
    [​IMG][/URL]
    [​IMG][/URL]
    [​IMG][/URL]
    [​IMG][/URL]
    the car come with a cool retro nardi not to everyones taste not normally mine but im staring to like it
    [​IMG][/URL]
    Right now the car is going to be used as a daily until i find something cheap,im unsure how far to take the car weather to get it up to bdc/competition spec or keep the intention as a nice drift toy.
    Things to come; the cars handbrake is pretty useless so i think i will opt for a hydro probably a duel set up with it being a daily, sort out the wiring behind the head unit, nice set of wheels iv been thisnking of the rota mxr's after seeing them on the driftworks r32 but id probably go for the polished or white finish.
    The Turbo feeds are rubbing against the cars maninfold which cant be good so i will get some braided hoses
    the actuator is also making a horrible rattle i dont weather thats something to do with it aswell or just the collar clip on the actuator bar is on its way out
    thanks for looking and i will post updates much as i can
    :dw:
  2. AnthDay
    AnthDay Member
    Delivery from japan new water and oil line kit ready for the turbo, the turbo is starting to smoke so these will be added to the replacement turbo
    i found the hydro i bought from epr back at awesomefest after it spent a while collecting dust, never really liked the look of them
    so repainted in matte black and opted for a bmx grip
    after upping the boost to 0.9bar the car seems to struggle, any rb25 experts know if this could be a coilpack issue ? or anything else and ways around it.
    next update will be hydro install and replacement turbo
  3. alexj
    alexj Member
    Holding back around 3500rpm on boost, then better after that? Classic R33 behaviour, a properly setup SAFC or something like it should sort that, or an ecu.
    If its missing, check coilpacks and gap plugs.
    #3 alexj, Oct 24, 2013
  4. Dennis-SX
    Dennis-SX Member
    Where dit you get the turbo lines from?
  5. AnthDay
    AnthDay Member
    Yeah alex it is better if I back off on the throttle and then plant my foot around 5000rpm is there any ecu's that are recommended ?
    I got these lines from kingawa turbos they have a few line kits for there own turbos too so make sure you select the right kit
  6. alexj
    alexj Member
    Yup that's it.
    s/h power fc is a tried and tested way to go even if its a bit stoneage £400 plus mapping.
  7. Jules_DK
    Jules_DK New Member
    I just got my R32 RB25DET swapped back today and it just runs awesome with that engine in! good luck with your car, its awesome
    btw, im Making 330 hp and 432 nm With at Gt28rs turbo and Apexi powerFC
  8. M!chael
    M!chael Member
    Looks mean!
  9. AnthDay
    AnthDay Member
    heres abit of footage driving the car through the tyne tunnel i was jus messing around in final cut pro
    the black and white makes it look mean as hell
  10. blazingburger
    blazingburger Member
    you lucky chap!
    keeping an eye on this thread ^_^
  11. LiamE36
    LiamE36 Active Member
    Christ, how long is that tunnel!
  12. AnthDay
    AnthDay Member
    haha liam hate admit we done a few tunnel runs because we are kids
  13. K P
    K P Member
    Sounds awesome :)
  14. AnthDay
    AnthDay Member
    finally gave my pal Dan the money for the xxrs so he gave me the other pair for the front
    So headed up to the garage to fit the hydro
    until this happened
    weirdly the brake line end that i bought from a local shop fitted on one side that came with an adapter but wouldn't on the other,
    im unsure what thread size is needed, cylinders been sent out to be rethreaded but in the meantime i bought another cylinder and have the same problem different thread yet again.
    any body no the right thread size for these ?
    cool shot from Shaun when i first got the car
  15. jon1200
    jon1200 Active Member
    looking good. its nice to see the comebacks of more r32's
  16. AnthDay
    AnthDay Member
    The hydro is now in but dosent really lock well with the 0.7 cylinder i bought so getting my hands on a .625 cylinder is now the next job. in the mean time i had a test fitting of the work equips i bought ages ago which were bought for my s13, all four need a good refurb two need sealing properly
    i can't remember what offsets they were, not a lot of dish but still look better than the xxrs, 10mm-15mm space they should fit quite nicely
    few more pics
  17. nick-sri
    nick-sri Member
    Great project!
  18. NickNitro
    NickNitro Member
    Awesome car. Will keep an eye on this one ;)
  19. AnthDay
    AnthDay Member
    heres a Problem iv got, that r32 now and then has this horrible idle, the car never looses power and cuts out but its getting more viscous as time goes on with it lasting longer getting more severe,
    plan is to take off the idle control valve, maf sensor give them a good clean and throw in some new colder plugs and see if it makes any difference.
    Also i don't know what possessed me in the first place but that piece of crap japspeed handbrake is coming out! its weak as hell I'm not the biggest and strongest of people and its bent already, how a big name in the uk drift scene such as japspeed could sell poor quality gear is beyond me
  20. AnthDay
    AnthDay Member
    progress has been slow due to buying my first property but this weekend i got a new delivery Supaforma uprated coil packs and white line control arm bushes
    after fitting the uprated coilpacks the car dosent struggle and pulls nice and smooth with no hesitation, when putting the coil packs on i also noticed yet another crack in the manifold
    the parts list is getting bigger every time like look at this car haha
