R32 Turbo Whine
Thread in 'Technical Questions' started by steely00000, Jul 19, 2011.
  1. steely00000
    steely00000 Member
    Chippenham
    Hi all.
    My R32 has developed a high pitch whining when on boost. I'm assuming it's turbo as it is only on boost.
    It seems to be more pronounced higher in the range, but it is there throughout the revs. Also, this happens hot and cold.
    Am I looking at a knackered turbo or something a bit simpler?
    Cheers in advance.
  2. Swampy442
    Swampy442 Active Member
    Lincoln
    Probably knackered bearings but take the intake piping off and look at the compressor, see if its touching the casing.
  3. stinky 32
    stinky 32 Member
    fife
    try the manifold to turbo gasket had the same problem on mine checked for a boost leak that was fine then thought i had fuked the turbo turned out to be tiny blow around the back of the turbo... fitted a nissan gasket and its all mint now.
  4. Ollie
    Ollie LOOSE!
    London
    turbo gaskets make a high pitched whistle when they are on their way out. replace with genuine nissan gasket and it will be gone.
  5. Gary.
    Gary. Member
    What they said, mines pretty much sounded like it was supercharged
  6. chris-s13
    chris-s13 Member
    scotland
    my s14 was doin this ,turned out it was a small slice in one of the intercooler pipes discovered it after i changed the turbo lol
  7. steely00000
    steely00000 Member
    Chippenham
    Cheers guys!
