For sale, my 1994 Nissan Skyline ECR33 GTS-T road legal track car. Mileage is 63,800 and it has all MOTs and History to back this up along with a CD full of photographic evidence of all work carried out both by myself and previous owner, both Skyline Owners forum members. The car is currently taxed & MOT'd until the 19th September 2017 and is completely road legal. There is a vast specification fitted to this, much of it is made by HKS (the industry leader of Japanese tuning components) which are of the highest quality and durability. It was fitted with an uprated HKS GT2835Kai turbo a couple of years ago (about 1000 miles ago!!), along with brand new exhaust manifold gasket and studs (all genuine Nissan) so this is a typical problem that will not need doing for the next owner. The battery is a brand new optima yellow top with a FIA engine cut off switch fitted to prevent battery drain. A new Link G4+ Engine Management System and HKS 550cc injectors with an NTK wideband lambda sensor were also fitted to control fuelling and ignition timing with full knock detection activated and mapped into it. There has been a lot of time and money lavished on this and it has the best of everything. Tyres, brakes, clutch etc all perfect. No work is needed. It's an awesome car and although perfectly useable and tractable on the road it really is a purpose built track car now, a little compromised for road work due to the safety equipment but awesome fun on the road nonetheless. Full Spec as follows... Engine RB25DET ( 455ps/415lbs/ft at <1.2bar boost) Silkolene Titan Pro S 10W50 Oil NGK Iridium IX Spark plugs Splitfire coil packs HKS GT2835 Kai Sports Turbine Kit HKS Stainless Steel Turbo Elbow Pro Tuner decat HKS Stainless Steel Front Pipe HKS Silent Hi-Power Exhaust System HKS Adjustable Actuator HKS reloaded induction kit HKS SSQV Blow Off Valve HKS Hybrid Sports Oil Filter (AK002) HKS 550cc Yellow Top Injectors (brand new) Link G4+ Engine Management system Walbro uprated fuel pump Electronics and Management HKS EVC 5 Boost Controller HKS A/F Knock Amp NTK Wideband Lambda Sensor with Syvecs ready plug and harness Field Harness Extension Defi Control Unit Defi 52mm Black Boost Pressure Defi 52mm Black Oil Pressure Defi 52mm Black Oil Temp Defi 52mm Black Water Temp Defi 52mm Black EGT Defi 52mm Black Fuel Pressure Defi Link Display Unit Defi Tacho pulse Sensor Set Defi Speed pulse Sensor Set Chassis Driftworks Coilover Suspension Driftworks front tension arms Driftworks rear camber arms Rear Sub frame polyurethane bush kit Steering rack polyurethane bushes Japspeed Hicas lock out bar Japspeed front strut brace Japspeed rear strut brace DB power 330mm Front Brake upgrade F+R Brembo slotted discs/EBC yellow stuff pads Driftworks Braided Brake Lines all round Ultralight nurburgring 18" x 9.5" ET20 deep dish wheels F+R Toyo T1R's 235/40/18 Front, 265/35/18 Rear Wheel arches rolled and flared Cooling Apex Performance Front Mount Intercooler Mishimoto Aluminium Large Capacity Radiator Mocal 19 row Oil Cooler Kit Nismo N1 Water Pump Blitz Sensor Adapter Sandwich plate Samco Silicone Coolant Hoses (blue) JDM Garage Water Temp adapter T piece Pro Tuner Fuel sensor fitting Transmission Transmission standard R33 5sp manual box 4.36 Final Drive Rear Viscous LSD Diff (geared for acceleration) Exedy Cerametallic S Type paddle clutch & cover Japspeed short shifter kit Nismo Braided Clutch hose Interior & Safety Apex Performance 6 point FIA approved full roll cage plus padding Recaro Furious FIA approved Side Mount Bucket Seats (driver and passenger) NG FIA approved Black 6 point harnesses (driver and passenger) Works Bell Rapfix II Quick Release Steering Nitosport Gearchanger Momo Race 350mm Steering Wheel HKB Steering Boss Driftworks (driver) and Bride double locking Adjustable Seat Rail Momo Leather Handbrake Fabricated aluminium door panels/quarters and rear panel Nissan R34 GTR Din Pocket Carbon Trim Dash Covering Fire extinguishers Interior stripped out rear and roof lining Red Arming Switch (Map change when cat equipped) BL Optronics 200 degree Green LED's to Combination Meter Air Con removed Exterior & Dress Up Nismo Clear Side Repeaters Customised front bumper Custom Front Number Plate Bracket NG 2" Black Harness webbing Door Pulls HID Main Beam Headlight Conversion Ice & Security Toad Cat 1 Alarm JBL Door Speakers The car is fitted with the latest Link G4+ ECU which is connected to the HKS NTK wideband equipped lambda module and also features full active knock control, able to retard timing in the event of knock events through poor batches of fuel and the like for greater safety and peace of mind. This mapping work was carried out by the reliable and renowned mapper Greg Gush of Protuner. I love driving it on track, the lack of ABS or any driver aids and the sheer response and feedback it offers are superb. The GTS is such an underrated car. Personally, on track I much prefer it to any of the GTR's that I've had and the soundtrack is awesome. Many of the parts fitted to this were bought brand new by me, ECU, Injectors, radiator, seats, harnesses, HKS Turbo, studs/gaskets. Most of the other remaining components were purchased brand new by its previous owner and I have a huge folder full of receipts. Condition is excellent. There is some corrosion to the lacquer of the rims, and a couple of light kerb rashes already there when I bought it (the tyres don't offer any kerb protection!). No rust whatsoever, the MOT testers always comment how clean it is beneath. Drives beautifully straight, full geometry print out in the file also. Ready to go...it's has been a hoot but it is time to consolidate all the toys as a growing family and the corresponding commitments means I can no longer devote much time to this hobby so it's time for someone else to enjoy her. This car is supremely reliable, the engine is strong and always run on Silkolene Pro S oil with HKS Super Hybrid oil filters. Dyno print outs (Pro Tuner) Boost Powergraph For any more information, pictures or videos please drop me a PM. £13,995 Thanks for looking. Cheers Nito
Thank you Some of its history, including all original japanese paperwork; Some more interior pics... And engine bay...
Refreshing to see a good decent ad with quality photos and full description etc! GLWTS Bump Bump Sent from my SM-G930F using Tapatalk
Eagle eyes It's a grand dearer in the Nissan section on PH! I didn't update price in the ad above written in June, but like it says above, I'm open to offers, Thanks chaps, Nito
Would you be interested in swapping + £3k cash my way for my Fresh import Single Turbo Mazda RX7? Advert and full spec on the for sale section
Just bought a motorbike so could do with the garage space, no one want this awesome RWD Skyline?! With the short gearing it goes like it has 100bhp more than it has, ie 550bhp!!
looking at a few skylines in various states of tune at the moment, what would be your absolute rock bottom price mate? also would you be interested in a 2008 Citroen dispatch van in part ex.... pm me if you like, thanks.
