r33 gtst front bearing removal?
Thread in 'Technical Questions' started by sx-si, May 18, 2012.
  1. sx-si
    sx-si anti-copy parts
    to take them out the knuckle is the big bolt at the back?
    i had a little look last night and couldnt really see
    been told they not like s14 bearings :(
    all iwant to do is fit longer studs pmsl
  2. skyline
    skyline Active Member
    easy job buddy hit them out pull new ones in, or if you really want to remove the bearing take the rubber cap off the top and you'll see a C clip, the reast is easy ;)
  3. sx-si
    ok i ended p removinstuubending the metal plate up and knocking them through
