R33 gtst rb25det not reving past 5500
Thread in 'Technical Questions' started by Lewis Dennison, Apr 23, 2019.
  1. Lewis Dennison
    Plymouth
    Hello there my r33 does go past 5500 revs when driving, in neutral it’s fine, also idles a bit crap drops then picks up then drops sometimes stalls
    Any ideas
    Thanks
  2. BenRice
    BenRice Well-Known Member
    Mt Maunganui, New Zealand
    Check your intercooler piping. I bet one has popped off and the pipe is just sitting against the joiner
    If not, check all intercooler joiners for holes or tears
    Post again with the outcome!
  3. Lewis Dennison
    Plymouth
    Thanks bud I’ll check it tomorrow and post the outcome
  4. Lewis Dennison
    Plymouth
    Also it sometimes isles low and stalls, it’s got new plugs and split fire coil pack, cleaned the idle valve, maf is clean also
  5. BenRice
    Also a symptom of a boost leak, however that could be a result of a bad AFM
    Does unplugging the AFM result in it idling?
  6. Lewis Dennison
    Plymouth
    The car cuts out when the maf is unplugged
  7. Lewis Dennison
    Plymouth
    All intercooler piping is fine
  8. Lewis Dennison
    Plymouth
    All intercooler piping/bends are fine
  9. orange_beastie
    orange_beastie Pickup driftin
    kings lynn / luton
    Could be your fuel pump? Are all the connections good and earths ect?
  10. Lewis Dennison
    Plymouth
    I’ve ordered a walbro 255 so will change it when that comes
  11. BenRice
    Ok. Fuel is definitely the next on the list, however if you haven't changed your fuel filter recently do this before fitting your new fuel pump
    Next could be voltage drop due to old wiring so you'll need to look at hard wiring the fuel pump - run a 30A fused 10-12GA wire from the battery to the fuel pump via a relay, using the existing power feed as the switched positive feed for the relay.
    Final thing could be faulty knock sensors causing the ECU to limit the engine prematurely
  12. Lewis Dennison
    Plymouth
    Just got a new fuel filter and walbro 255 fuel pump which is going on in the week failing that I’ll try the wiring and get back to you. Have been told it’s the ecu so have ordered a z28 ecu and getting it mapped
  13. BenRice
    Who told you it's the ECU? Sounds like someone with a vested interest in a retune to me...
  14. BenRice
    I'm not knocking getting a different ECU if it's something you'd like to do anyway, the factory unit is an utter pile of shit. If it senses the AFM maxing out, or too much knock it'll rich & retard the engine. Feels kind of like a limiter, but more like the engine is dropping an epic fart.
    That being said, your problem could be related to that. Like i mentioned previously a faulty knock sensor or AFM signal could be causing the rich & retard cut with load on the engine. Could also mean the engine is knocking...
    But getting a new ECU is not a fault diagnosis, especially when the recommendation is to upgrade it.
  15. smokebillowing
    West Sussex
    I know it sounds stupid, but check all fuses. My RB25DET did this once and it was the 'Engine control fuse'... Seriously.
  16. Lewis Dennison
    Plymouth
    Yeah that’s exactly what it’s doing, the engine sounds really nice no noises, may look into getting a new afm and sensor
  17. Lewis Dennison
    Plymouth
    Yes I’ll check them all and see what I can find thanks mate I’ll let you know once I’ve checked
  18. Lewis Dennison
    Plymouth
    Also should I get a standard rb25 r33 afm or go for the z32 afm
  19. smokebillowing
    West Sussex
    I also happen to have a stock R33 green label MAF for sale cheap if you want it.
    Z32 one will need a tweak to the map.
  20. Lewis Dennison
    Plymouth
    Message me mate could buy today
