Hey guys, need to clear some space so these bits must go! Prices are plus P&P or can be collected from RG45 Happy to hear offers, offer discounts for multi purchases, combined postage etc! R33 GTST Front cut knuckles - £180 £150 One bearing free, one seized R33 GTST / S14a extended LCAS - £120 £110 +25mm and braced for strength Genuine Bee*R Rev limiter - £110 £100 £90 Bought off of a member on here and never got round to installing it {} {} R33 GTST / S14(a) Lower control arms - £45ea / £80pair £40ea / £75pair £65pair No hole drilled for ARB {} R33 GTST +25mm wings - £130 £115 £100 Fibreglass GTR style non-vented, small chip on one corner but easy enough to build up {} {} {} Malpassi 1:1 Rising rate FPR - £55 £50 £35 {} Coolant temp sensor - £15 £12 £8 Comes in 36mm housing {} Polished R33 GTST coilpack cover - £25 £20 £15 Recently polished {} 3 gauge dash pod - £15 £12 £8 {} Prosport gauges - £20ea £15ea £12ea Coolant (sold) / Oil temp and oil pressure {} Mocal sandwhich plate - £30 £25 £15 Has take off for cooler and comes with oil pressure sender {} {} Genuine Bosch lambda for R33 GTST - £35 £25 £20 Under 5000miles on it, replaced it as part of testing and since proven working via Nissan Consult. Part # 258003256 {} GFB Dual port BOV - £80 £75 £65 Can be used to fully recirculate or vent or can do both (very useful for MAF based cars as it stops stalling and bogging on lift off) {} {} R33 GTST OEM "Type-M" Skirts - £OFFERS OEM, will need a slap of paint as the original is flaking a bit Thanks to anyone that has actually sat and scrolled through all of that! {}
Should fit an RB20 absolutely fine as it's a 3/4 unf. Not thermostatic. My understanding is you remove the water/oil heat exchanger and this fits in it's place or you'd need a replacement 3/4 unf stud (<£5)
hey mate, I'm interested in the remaining gauges, are these stepper motor type gauges? 30mm depth and 52mm wide?
Sorry for the later reply! I'll grab some measurements in a moment and PM you. Not sure if they've stepper I'm afraid
Can i get the lamber sensor for £25 posted? If so do you take paypal? Send us a message and ill get it paid.
