Hi all, rb25det running quite rich, can really smell it! Any idea if it can be adjusted/leaned off a bit without spending monies on an SAFC? Cheers
We have seen this problem loads of time before, normally the go to answer is fit a 1jz/2jz or LS motor. hope this helps.. lol
If it's at light throttle then get a new o2 sensor. Will improve economy massively if the old one is shagged. If it's at idle, check for vac leaks and clean AAC valve. If it's on throttle then get SAFC.
Lol @ Clarkey................................................dingus! Cheers Ben, I'll try the o2 sensor.
