R34 GTT 400hp Power upgrade All parts are NEW unless otherwise stated. All new parts are UNFITTED and only removed from the packaging for photos. Packaging may be dusty and/or have minor over spray but the items are unaffected ** I can hold item(s) with a 10% deposit (non refundable) Items will be held for 14 days unless otherwise arranged with the buyer ** Collection from Norwich, Norfolk is welcome Postage is within the UK (Northern Ireland postcodes may be slightly more) - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - New Hybrid Turbo (rated to 420hp) stock OE unit rebuilt by Universal Turbos £840 posted **SOLD** New Tomei Turbo Elbow £270 posted **SOLD** New Genuine Turbo Gaskets £75 posted **SOLD** Used Walbro 255 Fuel Pump £45 posted **SOLD** Used Apexi Power FC w/ commander £620 posted Used Z32 MAF with Apexi Filter £100 posted **SOLD** New Competition Clutch Stage 2 Clutch Kit & Lightened Flywheel £700 posted **SOLD** New Braided Clutch Line £25 posted **SOLD** New Splitfire Coilpacks £400 posted **SOLD** Turbo Specs are Re-Profiled Compressor Cover T38 Compressor Wheel 360 Degree Thrust Bearing T3 Billet Backplate Modified T3 Bearing Housing Modified Hi-Temp Turbine End Piston Ring Seal T38 Turbine Wheel Re-Profiled Turbine Housing Ported Wastegate and Larger Poppet Valve 1 Bar Actuator Up-Rated Actuator Bracket {} {} {} {} {} {} {} {} {}
whats the deal with the Z32 MAF is it a common upgrade for a stock engine? or is it used in conjunction with the Apexi power FC?
