Rb into ps13
Thread in 'Technical Questions' started by stichy, Oct 20, 2015.
  1. stichy
    stichy Member
    Will an rb fit straight onto an s body subframe ?
    And will an sr box bolt onto an rb ?
  2. 200sx_
    200sx_ PS13 x TD Power
    No, unless you buy conversion engine mounts. Most people run an R33 front subframe for the conversion if I remember correctly.
    And no again. If your going to run an RB25, just get the correct box as it's much stronger than the standard small case SR20/RB20 gearbox :thumbs:
  3. stichy
    stichy Member
    I'm aware the box is stronger but will it fit.
    It will be a DE swap and not a det.
  4. Dirk Jan
    Dirk Jan Member
    No it won't fit. Life isn't easy like that.
  5. BenRice
    BenRice Well-Known Member
    SR20 box vs RB20 box
    Bell housing bolt pattern (ie where it attaches to the engine) is different. Bolt pattern attaching to the gearbox case is the same.
    However:
    The RB20 box has a small case (second half) and longer bell housing (front half)
    The SR20 box has a longer case and shorter bell housing
    It is physically possible to interchange the two bell housings, however if you put an SR20 case on an RB20 bellhousing you will have an overlength gearbox. I also believe your input shaft will be too short and not reach the clutch
    There's the reason why it won't work
    Sell SR box, buy RB box
    You can use the front half of an RB20 driveshaft and the rear half of an SR/existing driveshaft.
    R33 crossmember puts the engine in the best position.
  6. stichy
    stichy Member
    that really great info,
    nice and easy then buy engine and box, as well as a 33 sub frame .
  7. sparky_s13
    sparky_s13 Active Member
    All that effort to fit a DE?
  8. RacerEdges
    RacerEdges Guest
    Go for 1JZ i think it's better for RWD
  9. Ollie
    Ollie LOOSE!
    Fuck yeah its that easy. You've made the metal lumps fit in the car you just turn the key and away it goes. There isnt any wiring at all to deal with.
