RB20 Coilpacks
Thread in 'Driftworks Products & Enquiries' started by Paul FWx, Dec 2, 2006.
  1. -WJ-
    -WJ- Dutch drifter
    I've got a set at home, and the instructions are very clear. Should be no problem!
  2. -WJ-
    -WJ- Dutch drifter
    ok, I've got a question...
    about the instructions :)
    In line 4 it says : To power the coil run the fat white wire from the 3 pin plug. This supplies the power to the coil...
    Which 3 pin plug is this? Fitting the kit tomorrow, just wondering about this...
    pleeeeaaaase help ;)
  3. Drift A GTR
    Drift A GTR Member
    wasted_spark_back. coil_diagram. DSC_0367. i fitted mine the other day IMAG0007. IMAG0009. IMAG0006. was peice of piss to do ,changed my plugs at the same time :) & get more flames from exhaust on gear change :thumbs:
  4. -WJ-
    -WJ- Dutch drifter
    I don't recall having that plug on my engine...
    I've got an RB25 in my S13, maybe I have got different plugs ?
    If I don't have the plug, what +12V source can I use ?
  5. Drift A GTR
    Drift A GTR Member
    these fit RB 20/25/26 IMAG0022. A pic of old gtr coil pack loom , you got 2 main connectors you need ,the ignitor plug (big one )& the main loom 3 wire one ,& 2 earth wires joined together with washer type connector to bolt to ignitor mounting to earth (black wires at the top centre of pic) its easy peasy mate :thumbs:
  6. robrs2
    robrs2 Active Member
    Any full wiring diagrams for this
  7. -WJ-
    -WJ- Dutch drifter
    eeehm...
    Drift A GTR's post is a full wiring diagram ?
  8. -WJ-
    -WJ- Dutch drifter
    ok, I deffo don't have that 3 pin plug...
    Where should I connect the white wire ?
  9. robrs2
    Wiring drawing from the ecu through to the new coil pack
  10. -WJ-
    -WJ- Dutch drifter
    :wave:
  11. Bon Bon
    Bon Bon It'll be fine
    Yours is an RB25 series 1 engine/loom with the ignitor pack, correct??
  12. iansr33
    iansr33 Member
    I have the same problem as -WJ- i only have two plugs, one with six wires and one with two wires.
  13. -WJ-
    -WJ- Dutch drifter
    yes it is, but the loom is somewhat chopped up, cause I don't have the little loop on the back that you can use to check timing...
    I've already been told I can use the +12v feed from the S13's IGN coil relay, so will use that :thumbs:
    Will post the results here, ofcourse :)
  14. james
    james Administrator
    Staff Member
    Have you got a picture you can post/send over?
    If the 2 wire plug has a big fat white wire, this will be the power wire to use
  15. iansr33
    iansr33 Member
    Will get some done tomorrow as its far too windy to open the bonnet to start messing around.
  16. DaveV
    DaveV Member
    I just fitted a set to an R32 GTR, took about and hour and a half and has cured my high boost missfire. Lovely :dw:
  17. -WJ-
    -WJ- Dutch drifter
    urgent help needed !!!
    ok, wanted to fit the kit today, and more mystery !!!
    My engine : (rb25det series 1 ?)
    my ignitor : (note : only 6 wires, on the ignitor to coilpacks side, no ground!)
    and finally my coilpack loom (see, only 6 wires, and the 2pin plug with the big white wire has been found...)
    Does this mean I can't fit the kit :( ?
  18. james
    james Administrator
    Staff Member
    No, it means it's easier :)
    In the last picture you posted, the plug with the pink/stripey wires is the trigger wires for the 6 cylinders. You can see the cylinder numbers on the ignitor.
    The fat white wire on the other plug is the main 12V+ power for the coils. The black wire there is for the earth, so join it to the engine block or somewhere like that.
    You run the fat white wire to one side of all 3 coil channels, then you join the pink wires into their pairs (1+6, 2+5, 3+4) and put each pair onto the other side of each coil channel.
  19. -WJ-
    -WJ- Dutch drifter
    :thumbs:
    any reason why my setup is like this though ?
  20. james
    james Administrator
    Staff Member
    That's just how the rb25 series 1 is done.
