Rb20det TD05
Thread in 'Technical Questions' started by Steve1093, May 19, 2015.
  1. Steve1093
    Steve1093 Member
    UK
    Apologies, as I know this has been covered before, but I'm getting a little confused (doesn't take a lot).
    Swaying towards a TD05 on my RB20. Does anyone know or have any experience on which would be the most suitable between the 16g, 18g or 20g etc and why? I've also heard the 8cm would be the best size to go for?
    If anyone has any figures for any of these, that would be great.
    Aiming for anywhere around 350 - 400bhp
    Cheers
    Steve
  2. C35Rob
    C35Rob Member
    Gateshead
    the TD06 20g is a great match for that sort of power on a 2.0 motor
  3. H05TYL
    H05TYL Member
    Land of the long white cloud
    A 16g td05 will do over 300 wheel horsepower, a 20g td06 will do considerably more but with a significant loss of response (which isn't an rb20 strong point to begin with).
    Imo a 16g td05 (8cm turbine housing and big compressor cover) is one of the best matches for a street rb20.
    Edit: 350-400 @ engine or wheels? If wheels then td06sl2 20g as above, if engine then td05 16g.
    #3 H05TYL, May 20, 2015
  4. Steve1093
    Steve1093 Member
    UK
    Thanks for the reply guys! Would probably be at the Flywheel, as it'll be a standard bottom end and don't want to push it too much.
    Want to start drifting it too, so ideally don't want it to be too laggy as it'll probably be rather awkward to get to grips with as I'm not very good haha.
    Think It'll be the TD05-16g, can always move on from there!
    Cheers guys
  5. retro-ed
    retro-ed Flicks 'n' Kicks
    Hinckley
    Use a TD05Hr 16G from an Evo.. fantastic 300-350+hp turbo on a 2L with mega spool. They are also cheap, bullet proof and easily upgradeable.
    Just need someone to fab you/modify a manifold
  6. Steve1093
    Steve1093 Member
    UK
    Cheers buddy, think that'll definitely be the way to go. Struggling to find any decent manifolds, so would go for a custom one anyway :)
  7. G535
    G535 Member
    West Germany
    Bringing this up cause I cant seem to find information regarding the fitment of an TD05 on a RB20. Obviously its a T28 flange okay. But
    Will it fit on a standard exhaust manifold with bottom mount turbo position using a T3 to T28 adaptor?
    What turbo elbow will I need to make it bolt onto the standard downpipe?
  8. H05TYL
    H05TYL Member
    td05's don't have a t28 flange... Kinugawa sell t3 flanged exhaust housings to suit td05's (in several sizes and internal or external gate versions)
  9. G535
    G535 Member
    West Germany
    Yeah I found the Kinugawa T3 flange ones after I posted in here. Seems proper :)
  10. G535
    G535 Member
    West Germany
    Does anybody know where to buy an internal gated TD05? I dont really wanna mess aroound with custom fabrication for an external wastegate
