Rb25 32 wiring
Thread in 'Technical Questions' started by scottyboy, Feb 26, 2017.
  1. scottyboy
    scottyboy Member
    Can the car crank over by the key with just lower charging/gearbox loom or does it still need the engine loom just want to eliminate wiring issues, also the gearbox manual neutral switch if its switch off or on does that effect starting the car
  2. Tommy59
    Tommy59 Active Member
    Milton Keynes
    If it's being converted to from auto to manual you need to loop two wires to make it think it's always in neutral, if you don't loop them, it won't start
  3. scottyboy
    scottyboy Member
    Thanks not converting from auto always been a manual
