Have a full rb25det conversion for sale, Engine is a spec 2 which came out a 58000 kilometre car , so around 36k Engine is very strong and had good compression when installed. Engine runs fine no horrid noises, no using oil or water, Gearbox is sweet no noises or crunches, Act sprung clutch not harsh so won't kill the box Conversion prop made and balanced. Comes with down pipe Front skyline subframe Pink maf Conversion wiring loom Mapped ecu Intercooler core Hks adjustable actuator Braided oil & water turbo lines Oil sandwich plate & modified coolant pipework. I have a Syko performance mouting kit imported from America including spacers for the arb. Car was mapped at rising sun up to a solid reliable 307bhp, goes very very well and well looked after. I would rather it go as a package but would sell the box & prop separately if the engine sells 1st. I have stripped the engine to the small block & cleaned it then painted with enamel paint. Fitted new exhaust manifold studs. New injector seals & injectors flow tested. Fuel rail anodised. Inlet manifold vapour blasted. New rocker cover gaskets. New inlet & exhaust gaskets. For the whole drop in conversion I'm looking for £3000. I can sell all parts separately but the engine will need to be sold 1st. Pics next.
I can ship to anywhere if the courier is covered. I have shipped engines before & I know this will be 2 separate pallets.
Parts now availabe separately. Engine. Spec 2 loom & ecu. Rb gearbox. S13/rb propshaft. Fmic core. Syko engine mounts. Rb crossmember with s13 steering rack & polybushed mounts.
