rb25det will not crank
Thread in 'Technical Questions' started by Joshua Pickens, Apr 13, 2019.
  1. Joshua Pickens
    Joshua Pickens New Member
    tennessee
    i have an rb swapped s14. i had the starter checked, and it has a new battery. the engine is not seized, but when i turn the key, the starter makes a noise like its trying to engage, but then starts clicking. i have a wiring specialties harness and everything is hooked up properly. someone told me it might need a shim but ive never heard of anything like that on a late 90s japanese car. any input would be appreciated.
  2. Andy318ti
    Andy318ti Active Member
    Edinburgh-ish
    Have you fitted a heavy ground strap from your engine block to the chassis?
  3. orange_beastie
    orange_beastie Pickup driftin
    kings lynn / luton
    Sounds like power issue check main power to starter and a good earth strap near starter on block to chassis rail.
  4. Staubwedel
    Staubwedel New Member
    Lose bolt on the starter wiring?
    Grounds checked?
  5. Joshua Pickens
    tennessee
    yep. it was a poor ground. I got the starter to crank
