Rb26 Fuel rail
Thread in 'Technical Questions' started by PHIL-BLR, Jul 12, 2018.
  1. PHIL-BLR
    PHIL-BLR Member
    the rock
    I've been looking for an rb26 fuel rail an 99% of ones available for every other car are around £100 and get good ratings but when you type rb26 it goes to £200-250 wtf they do exactly the same thing..
    Anybody Got any links to a good quality rail for reasonable money..
    Thanks in advance
  2. s15-newbie
    s15-newbie Member
    Germany
  3. PHIL-BLR
    PHIL-BLR Member
    the rock
    Yeah but I'm afraid of them leaking would be nice to hear from some one that uses one..
    I don't mind paying for an expensive one if their was a reason other than it being rb26 than rb25 1jz 2jz they all do the same job
  4. s15-newbie
    s15-newbie Member
    Germany
    i was using this fuel rail with RC injectors in my S15 with RB26 build a few years ago.
    if you are worry about leaking you could change the o-rings for the injectors for oem o-rings and the gaskets for the dash fittings you could change for copper rings. by the way... i don´t see any problems with this fuel rail, as its just a piece of aluminum. only leaking part could be the gaskets but i don´t had any problems with them.
    but you should look which diameter your fuel injectors have. (like 11mm type or 14mm type)
  5. PHIL-BLR
    PHIL-BLR Member
    the rock
    Thanks I was thinking the same about the rail itself all 6 pot stuff is basically the same thing just different mounting points
