nissan skyline r32 gtst ( RB26 ). I never thought I'd be writing this but as other commitments arise there maybe an opportunity for someone else to take on and finish my rb26 r32 The engine is a great spec it has Overbored 0.5mm Pec rods Wossner pistons Acl race bearings Brand new nismo oil pump Brand new water pump Genuine nissan gasket kit Tomei oil restrictor Hks 272 cams Brand new valve guides Brand new valve stem oil seals Hks timing belt kit Valves re lapped Head stripped and cleaned Brand new rear main seal Superforma half moon seals Tomei engine ornament Spec of the r32 consists of Engine bay stitch welded and painted nismo grey (all holes welded and smoothed) New clutch master Brake master cylinder New brake lines up front Interior: Boot floor and firewall custom made as the car was a drift car Cage and Interior painted nismo grey Sound deadened Carpeted Underside: Both subframes powdercoated All arms under the car are adjustable from driftworks Steering arms from japspeed Steering rack spacer Solid engine mounts Solid subframe bushes All nuts and bolts replaced with zinc HKS coilovers And runs a LINK ECU I have side glass and rear quarter glass as for front and rear I wanted new and the kit I was going to order a ep racing pandem kit as it comes with everything that's why it has 12 inch rear wheels to fit This is an unfinished project and will need time and money to finish it will need Bodykit Fuel system Lights Windscreen front and rear Brakes And a full drivetrain to complete The car is on irish plates and is up to the new owner to register it I am looking to swap for a running driving car as I do not have the time for the skyline anymore due to other commitments. Thanks for looking {} {} {} {}
