RB30'ing a 33 GTST
Thread in 'Technical Questions' started by zombie, Jun 26, 2009.
Tags:
  1. zombie
    zombie Active Member
    gloucester
    ..i want to something really special with the build im doing at the moment
    and i really need to start making some concrete decisions as far as the engine goes
    up untill now ive been dead set on building a nice high tune rb26
    but
    im starting to think i wanna do things a little bit differently
    and the strength of the rb30 is really appealing
    and id prefer to run a down tuned road map on the rb30 and turn it up for track and it handle it no probs
    rather than the rb26 being pushed 24/7
    now i dont want replies saying "go for the 26" blah blah blah
    what i want to know IS
    what is involved in the conversion ?
    can i jus get an rb30 block (maybe from the aussie commodore??) and 26 head and make the rb30 engine complete myself
    i know rips nz are like the authorities on this subject
    can i use an rb25 gearbox?
    the sump will have to modified if im correct?
    any help appreciated
    even better if someone could just to a few * bullet points
    and go bang bang bang thats what you need
  2. Hexham-Scotty
    Hexham-Scotty skylinepart.com
    Up Norf
    Drop me an email info@japanimportcar.com
    I have all the info on my work pc.
    Deffinatly worth doing the 30 conversion
  3. Mr Bizzle
    Mr Bizzle In Safe Hands
    Bicester, Oxfordshire
    RB30 conversion...
    Kind of a big box of worms your opening there mate. Very simply there are two ways to do it.
    Option one, is get a stock RB30, land a 26 head on it, buy a new timing belt, sling it back in the car and drive on with a reliable 400hp/400ftlbs all day every day. But it does have some weaknesses.
    The RB30 uses the short nose oil pump drive collar (as does the early R32 RB26's) this is a fairly large problem on drift cars as you spend a lot of time sitting on the rev limiter and within an astonishingly short period of time the oil pump drive ends up spinning in the oil pump, causing zero oil pressure and fucking your engine. This is really easy to solve, but does require a complete rebuild and taking the crank out and getting a collar (available from spool or soon from JDM Garage) interference fitted.
    Top, short nose. Bottom, Long Nose (see the flat contact patch difference)
    shortnosevslongnosecranks.
    RB30's will take either an RB25 or RB26 head without messing with the block too much. RB26 is a million times easier as you don't have to fuck around with sorting oil feeds for the VVT system. To do a 30/26 you basically use all RB26 parts for the head and a complete OEM Nissan RB26 gasket kit. (with your choice of head gasket)
    Option two is that you build a proper RB30/26 with forged internals. The crank is pretty bullet proof and the rods will do 500-600hp as will the pistons providing that you map it properly, but that's using new or good condition OEM parts which are hard to come by. My recommendation is that you speak to Spool in Australia. They do complete rebuild packages with Pistons, Rods, ACL bearing and ARP fasteners for about £1500 landed here in the UK.
    RB30 will take RB26 Oil and Water pumps plus pullies, thermostats etc.
    Make sure you sort the oil control issues with the 30 before you put it together. The RB30 has two very large oil feeds (one at the front and one at the back of the block) these are a fair chunk bigger than standard RB25/26 oil ways and magnifies the "Oil pooling in the head problem" (See this link: http://www.driftworks.com/forum/tec...g-issues-why-do-rbs-blow-up-answers-here.html)
    Drain kits can be bought from JDM Garage and machining to the block/head/crank can be done at any good machine shop.
    Hope that helps you a bit.
    Checkout Skylines Australia and read the RB30 specific threads. Pages and Pages of info there and should be all you will ever need to know.
    RB30 conversions - Skylines Australia
    #3 Mr Bizzle, Jun 26, 2009
  4. zombie
    gloucester
    scotty your a fucking ledge
    i jus wanna build a car im proud of
    and the car i want
    and i wanna leave shit stains on the bride buckets everytime i get out
    wether on the track or going to pick up some fags from tesco
    so it seems the natural progression
    and although i dont wanna skimp on it
    id rather do it the most economical way possible
    ie not going out and spending 10k in one hit to have a rips rb30 sent to me
    i wanna build the fucker from ground up lol
    will send you the email now scotty
    btw you get the gearbox safe and sound?
    soz about the dust sheet, but i ran out of bubblewrap :D
  5. zombie
    gloucester
    thanks for the info as well bizzle
    really appreciate you taking the time to write that
    im liking the sound of option 2
    so the general consesus is its do able, not the hardest in the world
    but theyre are jus oiling issues that really cannot be ignored
    but as long as theyre seen to its all gravy baby :D
    just out of interest, which of these 2 routes did you go down scotty?
    im presuming number 2?
    when i get home later tonight i will read your build thread from start to finish
  6. Mr Bizzle
    No problems mate,
    Got to help people out with stuff like this! Scotty went with the spool kit :) (im pretty sure)
  7. zombie
    gloucester
    Sweet man. Yeah and 1500 seems reasonable for the security you get from the kit
    I'm probs gunna go for a standalone ecu anyway and a decent mapper isn't an issue
    So that's that sorted at least
    How much will an rb30 block rush me ? (Again from the commodore isn't it?)
  8. Mr Bizzle
    You want a series II block as they have oil/water feeds already drilled and tapped from the factory. Get yourself an RB26 Power FC and get Steve Sadler from FC Tuning to map it. He's done quite a few now and is in regular contact with some of the big tuners in AUS who do these day in day out. Think he's currently at 550hp on a standard internal one that's in Stu's S13.
    Stock series II here in the UK is £500-£600 but that's if you can get hold of one.
  9. zombie
    gloucester
    Cheers
    Its jus hard decyphering all the crap on the net to find the bare facts of what I need
    Ok well that's an extremely reasonable base to start with
    But I take it they're jus in short supply then?
  10. Mr Bizzle
    Here in the UK yes they are. In Aus/NZ they use them as doorstops.
  11. zombie
    gloucester
    Ahh yeah found a few
    Bout 250
    But then 300 shipping to get to the uk
    Then to the door shipping on top
    But that's not too bad. Awsome
    My spirits are high
    And I thankyou.
  12. zombie
    gloucester
    sorry just one more thing bizzle, did you use the stock rb30 sump?
    does it require any modification?
  13. Mr Bizzle
    RB25 sump :) But you need to slightly modify it because the RB30 crank counterweights are slightly bigger than the 25's so the cooling fins/baffling catches on the crank as it rotates.
    Easy fix
  14. zombie
    gloucester
    happy days
  15. waxer52
    waxer52 Member
    I built mine in my shed. Rb25 head and gearbox. You can do it all yourself if you are handy with some tools.
  16. zombie
    gloucester
    yeah man
    although im gunna go for the 26 head
  17. zombie
    gloucester
    sorry onnnneee last thing,
    would it be beneficial to just run a dry sump setup?
