im looking into getting a set of r1 carbs for a chevette i should be getting, were can i get the correct jets to make it fuel right?
you can get jets cheap as chips from most bike garages, your best bet would be to get the fueling checked as it stands now, it might be ok as it is and just need the needle raising a little. if it needs more then just get some larger jets in size incraments of 5 (you can go up in 1 stages but its really not worth it as its such a small difference)
