Real world reviews on BMW > JZ Gearbox Adapters?
Thread in 'Technical Questions' started by chopaholic, Jan 16, 2019.
  1. chopaholic
    chopaholic Active Member
    Ireland/Lincoln
    I am very soon going to be in the market for an Adapter plate to suit a GS6-53DZ HGU gearbox mated to a 1JZ.
    I’m reading various mixed reviews on multiple companies, so far ive been focusing my interest in the kits offered from PMC motorsport and FTWL motorsport, this is due to price, seemingly fairly good quality stuff and so far fairly decent customer service. I have pretty much wrote the ABC and Collins kits off due to price.
    But does anyone have any real world experiences with PMC or FTWL kits? There has been a few threads on here with comments based on hear say, I seen a horror image of an FTWL kit destroyed the first time he went drifting but any review I find on the internet are in praise of the quality of the FTWL stuff.
    I would like to know how they stand up to drifting, how they fit and your opinions on your setup, also what setup you are running?
    People have mentioned the PMC kit rattles which would not be ideal, anyone experienced that?
    Many thanks,
    Dylan.
  2. jon07043278
    jon07043278 Well-Known Member
    North Wales
    I have the pmc kit, not the finest piece of engineering but it did bolt up ok. I am having real issues with the clutch not disengaging enough.
    If i were to buy again it would be the Driftmoto kit. Only a little more expensive but heard better things.
  3. chopaholic
    Ireland/Lincoln
    Thanks for the comment man, do you have any idea why its not disengaging? Was the slave pin lengthened?
    Also, been looking at this Adamat kit if anyone has seen it, looks promising.
    https://adamat.com.pl/blog/1jz-2jz-dwutarczowe-sprzeglo-wyczynowe-do-skrzyn-bmw-nowa-wersja.html
  4. jon07043278
    North Wales
    Not sure. The kit came with a longer pivot made of brass to replace the nylon/plastic stock one. I tried making a longer pivot and it made it better but still not correct. Will have to do some trial and error but really it should work out of the box.
  5. jay-young
    jay-young Active Member
    Isle of Man
    Lexibreak may be worth checking out. I'm looking at doing a manual swap on my JZX using the IS200 J160 gearbox and they are producing a full kit. Made in ireland so potentially easier to get support after you've bought it.
  6. chopaholic
    Ireland/Lincoln
    The issue with the J160 box is power, Its the same box used in a 6 speed S15 and I don't think they can hold that much power.
    Jonny Irwin at MCL makes the conversion too and its very affordable, but not sure if it will suit this application.
  7. Japtorque
    Japtorque Member
    KENT
    what sort of price is it to have the custom prop shaft made? that bit has always held me back before, the rest of the kit is basically a clutch and adapter plate
  8. jon07043278
    North Wales
    As long as you have both ends it should cost between £40-£100 depending on how difficult. Just measure the length and send the parts, easy.
  9. chopaholic
    Ireland/Lincoln
  10. jon07043278
    North Wales
    The PMC kit is a single piece flywheel using the stock flex plate (i think that's what you're saying). There is nothing wrong with that as an option.
  11. chopaholic
    Ireland/Lincoln
    Yea mate it put me off a little with the amount of bolts but seemingly it’s tried and tested.
    Which type clutch did you go for? Also what style gearbox you running mate?
    #11 chopaholic, Jan 21, 2019
  12. jon07043278
    North Wales
    There aren't any more bolts. The flexplate and flywheel are bolted through to the crank using the same bolts :)
    The same box as you're looking at (GS6-53DZ). I bought the stock sachs clutch kit that came with it but use it as a spare and just bought an uprated E60 530d paddle clutch from CG clutches. That's what is fitted atm.
  13. chopaholic
    Ireland/Lincoln
    So, to update the thread for anyone who is interested, after lots of research I ended up going for the FTWL Motorsport twin kevlar kit, it arrived today which was super fast delivery. Looking forward to my 1JZ to arrive now to see how it fits up.
    proxy.php?image=https%3A%2F%2Fi.imgur.com%2F5c6XPsy.
  14. jon07043278
    North Wales
    Great update :)
  15. stevieturbo
    stevieturbo Member
    Norn Iron
    Holy shitballs at the height of that flywheel !!!
  16. chris1986
    chris1986 Member
    Spijkenisse, Holland
    Is there any news about this.
    Can u tell us why u went with the ftwl kit?
    i am also very curious about this.
    Want to convert my is300 2jzge to manual with a turbo kit later on.
    The bmw gs6-53dz/bz seems the cheapest and most reliable option.
    But i am still stuck between pmc, ftwl and adamat.
    The car is a daily driver with occasional drifting/track use.
    Any input is welcome.
  17. chopaholic
    Ireland/Lincoln
    About 5 of us have purchased the FTWL kit now and have been very happy, with the correct diff the GS6-53DZ is fantastic.
