REAR RAD BUILD WATER PUMP
Thread in 'Technical Questions' started by DRIFTJAY, Apr 7, 2019.
  1. DRIFTJAY
    DRIFTJAY New Member
    Hey, in a bad spot hear, tried everything i can think of to bleed air out of the cooling system, set up, rad in the rear davies craig pump on a z32, anyone point me in the right direction of how to get the air out? cheers
  2. BenRice
    BenRice Well-Known Member
    Most tool hire places will have what's called a vacuum bleeder that you can connect to a fluid system to draw out any air pockets
    I've used one of these on brakes and they worked amazingly, and have heard of people using them on rear mount radiator systems as well
  3. r3k1355
    r3k1355 Well-Known Member
    Where are you trying to bleed the air from?
    The air will usually get stuck in the higher points in the system, if your rad/expansion bottle aren't the highest point then trapped air is quite likely.
    If the rad is at the rear then jack the back of the car right up in the air, then run the car and hopefully the air pockets will move.
  4. Andy318ti
    Andy318ti Active Member
    Do you have any bleed points in the engine bay?
