Hi, Up for sale is my set of 4 Rota rkrs. All 4 are 17x9.5 et-10 Matte bronze 2 of the wheels are still in the box in their little protective shower cap thing, and 2 have tyres fitted (which will be removed as ill keep them for skid rubber) but they are unmarked and exactly as they came out the box. Only briefly test fitted one of them. SOLD
Ideally like to sell them all together, but if someone else only wants a pair as well then Ill be happy to split them
yeah to clear them with the brembos they need a minimum 20mm spacer (you can see how close it is in the photos, thats a 20mm) , 25mm to have good clearance. I don't know how much shallower standard brakes are though :/
Euro, Ive added more photos to the original post. Rears I THINK didn't have a spacer on and would fit with a good pull/flare or a 30mm over.. The fronts had a 20mm spacer to clear bigger brakes.. They should be ok with overs/pull, a bit of camber with standard brakes (if you have them) Update: This is a mates 15 with some on, with overs (not too sure on the sizes) but with I think 25mm spacer up front and a 20 in the back.
Unfortunately not as I do really need the space :/ but if you only want a pair I'm happy to split them between you and Chris who also wanted two
