RWD Nissan gear ratios
Thread in 'Technical Questions' started by James_H, Mar 24, 2010.
  1. James_H
    James_H Member
    Its not all of them just the most common.
    I've been searching for this info for the past few hours and wanted to put it somewhere abit more permenant than my dodgy computer that always gets wiped!
    I hope it might help some others but its mainly for my own reference and benifit :dw:
    This is what i have found:
    CA18DET
    1st: 3.321
    2nd: 1.902
    3rd: 1.308
    4th: 1.000
    5th: .838
    Reverse: 3.382
    Final Drive: 4.363 (outside of Europe!)
    Final Drive: 3.916 (European)
    SR20DET (5 speed)
    1st: 3.321
    2nd: 1.902
    3rd: 1.308
    4th: 1.000
    5th: 0.759
    Reverse : 3.382
    Final Drive: 4.083 (S13)
    Final Drive: 3.692 (S14 Manual)
    Final Drive: 3.916 (S14 Auto)
    RB20DET
    1st: 3.321
    2nd: 1.902
    3rd: 1.308
    4th: 1.000
    5th: 0.759
    Reverse: 3.636
    final drive: 4.363
    RB25DET
    1st: 3.214
    2nd: 1.925
    3rd: 1.302
    4th: 1.000
    5th: 0.752
    Reverse: 3.369
    Final: 4.363
    VG30DETT
    1st: 3.210
    2nd: 1.930
    3rd: 1.300
    4th: 1.000
    5th: 0.750
    Final drive: 4.080 (NA Model)
    Final Drive: 3.692 (TT Model)
    #1 James_H, Mar 24, 2010
  2. lsd32
    lsd32 Member
    i thought that the final drive on skyline manual was 4;1 and 4;3 on autos
  3. Dunkz
    Dunkz Garage LSD
    I think you need to do your research again, you've at least got the ca and sr final drives wrong. :nod:
  4. James_H
    James_H Member
    OP Edited. Turns out it wasn't wrong just didn't have enough info. There are different Final drives for Europe and the the rest of the world.
    Keep it coming, i will keep trying to get it as accurate as possible.
    #4 James_H, Mar 25, 2010
  5. lawina
    lawina Member
    That is some usefull info :) I'm going to change my stock diff to a s14 diff, and now i know that the diff from auto tranny will be the thing i'll be looking for :)
    Anyone knows if the diff from rb25 would fit in s13?
  6. al.
    al. actually dom joly
    liner diff will fit s13 with an s13 backplate and halfshafts as the bolt pattern is different on the driveshaft flanges.
    just to add a bit more info....s14 final drive ratio is 3.6:1 (48 ring gear teeth/13 pinion gear teeth) for the manual, and 3.9:1 (47/12) for an auto
