S-body uprated and stock parts plus skyline gtr seat, navan spoiler, japspeed track rods etc
Thread in 'Parts for sale' started by dandadude, Mar 29, 2017.
  1. dandadude
    dandadude Active Member
    Having a clear out. All prices are collected, I am located in Newton Abbot Devon. Happy to post things but pm for prices. Ask for specific pictures as haven't photo'd everything yet.
    Offset rack spacers, used but in good condition, threads and tabs all intact - £60
    s14 Navan rear 3 piece spoiler with brake light - requires prep/paint as lots of marks and scuffs, all rubber gaskets intact except 1 but should be fine to use some tape/silicone to seal - £80
    R32 Skyline gtr driver seat - in average condition but material has been repaired and bolster on drivers side worn on the lower part from getting in and out, - has an extra tab welded on rail to allow fitting to s-bodies, was used in my s14 daily and very comfy, a lot more supportive than the standard leather seat. £70 including rail
    R32 seatbelt stalk - can come with seat above or sold on it's own, fairly sure it's same as s13 but different to 14/15s - SOLD
    Universal intercooler - few dents etc but holds pressure - £30
    Oil sandwich plate for gauge take off's comes with ca thread adaptor and a couple other random ones - would advise new o-rings as the outer one is starting to perish - £12
    65mm oil pressure gauge in used but working condition - requires a 2 post sender to work which is NOT included - £15
    Standard parts:
    Full set of front and rear s14/14a seatbelts - £80
    s14/14a front black leather seats, passenger seat very good condition, drivers side ok, tear on outside of bolster and could do with a clean - £40 for both
    10 front wheel studs, standard length s14/14a - all threads ok - £15
    S13 ecu - see photo's, was bought by mistake for a friend but never used. £40
    s14a genuine nissan cat and standard turbo elbow, comes exactly as pictured with nuts and bolts and small o-ring style gasket - down pipe has been cut down so as easily interchangeable for MOT time - dry stored for a few years. £80
    s14/14a standard cast exhaust manifold with egr bunged - very small hairline crack on the turbo divider - £20
    s14/s14a/s13 standard rubber sr gearbox mount comes with nuts and bolts and L shaped bracket - £10
    1 s14a foglight which has 1 bracket cracked and small hole in plastic backing - £10
    s14a standard parcel shelf with speaker covers - most clips intact but a couple missing - SOLD
    s14a standard steering wheel with airbag - £15
    s14/14a a/c compressor/pump - worked fine before removing last year - £35
    s14a a/c bracket on it's own, no pulley/tensioner - £15
    s14a front bumper headlight washer pipes and connection, 1 plastic connection broken otherwise good - £15
    s14/14a a/c fan - £15
    s14/14a knuckle/hub to coilover bolts x 4 - £10
    s14/14a standard rear camber and toe arms - £15
    s14a dash in very good condition - no holes or cracks - £60
    Full s14a passenger airbag to airbag ecu and wireing harness - £50
    Have loads of standard interior, sun visors, rear quarter plastics etc
    Link to photo's - slowly uploading the pics
    https://drive.google.com/drive/folders/0B2sHeyZr5VmAQ05kZmtBX3ljYlE?usp=sharing
    #1 dandadude, Mar 29, 2017
  2. dandadude
    Clock spring sold
  3. dandadude
    Track rod ends sold
  4. AdamS14a
    AdamS14a Member
    Hello mate any pics of the rear bench? Would need it posted also
  5. dandadude
    I can get pics but I would think postage will double the price. I will add some pics to the album! Pm me if still interested. Cheers
  6. dandadude
    Rear seats/bench sold
  7. dandadude
    Bump - got a few more bits such as standard leather seats etc in the garage just ask if not listed. Cheers
  8. dandadude
  9. dandadude
    Momo boss sold
  10. dandadude
    Pics of kinked tension rods added to link
  11. connorqueen
    connorqueen Member
    Still got the R32 seat belt stalk?
  12. dandadude
    Yes, sending you pm
  13. dandadude
    R32 stalk sold, also have front and rear s14/14a seatbelts with stalks. Front seats also available
  14. dandadude
    Bump - offset rack spacers added!
  15. LUX1
    LUX1 Member
    pmd
  16. dandadude
    Replied
  17. dandadude
    Bump, got loads of interior bits like door cards etc as stripped car for cage. Ask and I may have it. Cheers
  18. dandadude
    Parcel shelf, main floor carpet and roof lining sold
