S CHASSIS Alignments
Thread in 'Technical Questions' started by mitto, Mar 15, 2012.
Tags:
  1. s13..kev
    s13..kev Member
    kildare,ireland
    What you think of this set up.modded hubs with 40mm rollcenter.20mm extra in lower arms.rack moved 20mm.rear subframe tilted with type-he windinmasters tein coilovers all round
    Front
    Toe... . zero
    Camber... -3.5
    Castor.... 6.3
    Rear
    Toe... -0.05
    camber... -0.30
    Car is a ps13 sr20 350 hp running 225.45.17 Tyres all round.r888 toyo's front and any kind of second hands i can find :p
  2. magicmat
    magicmat Active Member
    W.Yorks, Wakefield
    Could you educate me on wheel sizes? mainly is it better to have staggered or the same size front and back?
    Would having a front wheel 0.5-1J smaller reduce oversteer and spinning when drifting?
    Or does it mean naff all??
  3. japdrifter_s13
    japdrifter_s13 running out of skill
    slough berkshire
    They exist to me since I drive one daily, so any ideas on what would work on an 25'd s14a?
    Hsd monopros on a 10/8 spring set up, full alignment arm kit and no anti-roll bar?
    Based on your streeto set up?
    At the moment caster feels good, i beleive its the standard nissan s14 castor setting, and transitions quite nicely, the main issue I have is carrying speed through corners, whether I try to feather the throttle to try and gain a little grip to push me forward or deck it and rip through the gears it doesnt seem to pick up speed through the corners, well it does but by no means as fast as I'd like. A mate keeps having to back off in a v6 sierra as he picking up way more speed than me, and is constatly able to sit on my rear quarter whereas with him in front he can slowly pull away from me. this is no good :thumbs:
    At present I'm running nearly 4degrees of rear camber until I go for alignment,and unaligned rear toe, could this be my "carrying speed" issue?
    #43 japdrifter_s13, Sep 10, 2012
  4. driftescort
    driftescort Active Member
    Cork, Ireland.
    Of course this is your problem. You are never going to build speed if only half your tyre is on the ground.
    Don't forget that when your car squats on power you will have even more camber.
  5. Dex
    Dex kut!
    Clogsville
    deffo, im rocking 7,5 rear neg camber, as soon as you go sideways, it just doesnt speed up, doesnt slow down either, but you can feel the lack of grip
  6. Dale H
    Dale H Member
    Hinckley , Leicestershire
    hi all......
    could someone give tell me the best camber and toe settings for a 2 door r32 gtst please
    i have fully adjustable arms front and rear and im going to get it all setup tomorrow at my mates but cant seem to find any setting
    i will be using the car for street and drift days
    also could i have the measurements in degrees and mm please front and rear toe and camber
    thanks
  7. mattyb123
    mattyb123 Member
    gateshead
    hey mitto any chance you could give me some pointers on my alignment,
    got superclarkey front knuckles
    bottom arms extended 25mm
    dw tension rods
    dw rear camber
    dw rear toe
    dw rear traction arms
    on an s15.
    thanks in advance
    just noticed you posted one for the same setup as mine,
    #47 mattyb123, Oct 9, 2012
  8. Silvi
    Silvi Member
    As I see lot of people using 0'05" of toe Out.
    I guess its 0.05 Inch, Is it per wheel or total?
  9. Mau5
    Mau5 Member
    Perth,WA or Leitrim, Ireland
    degrees and minutes dude!
  10. voxhel
    voxhel New Member
    hi,
    i have tried change my alignment to the
    MINIMAL STREET / DRIFT USE
    FRONT
    camber 2'50"
    castor 7'30"
    toe 0'05" OUT
    REAR
    camber 1'10"
    toe 0'10" IN
    but i can not get better than this;
    FRONT
    camber 2'50"
    castor 6'43"
    TOTAL toe 0'05" OUT
    REAR
    camber - 2'16" !!!
    toe 0'10" IN
    Any idea how can i solve this?
    It's a s14 - kenzi
    thks
    vox
  11. kam
    kam I've touched Chris Parry
  12. voxhel
    voxhel New Member
    kam
    ok i have read better :) that kit solves my alignment problems.
    do i still need the Driftworks GeoMaster - Offset Rack Spacers or only with this changes i do not need then?
    thks
    vox
  13. kam
    The tension rods in the 4 arm kit will adjust your caster :)
    You only need Geomaster offset rack spacers if you have modified hubs and are experiencing over centering.
  14. progressivez33
    progressivez33 New Member
    North Cyprus
    got DW geomaster 2 front knuckles
    arms extended 25 mm
    geomaster tension roads
    DW offset rack spacers
    :dw:
    cusco rear camber
    cusco rear toe
    cusco rear traction arms
    front Federal RSR tyres 225/45/17
    rear variable but 235/45/17
    Nissan Silvia s15 its around 360 bhp
    thanks
  15. CJRdrift
    CJRdrift Member
    East Anglia
    I just posted too regarding the issues I'm having I see your results but use my car as a weekend street and soon more track next year put pushing hard into corners, switching etc is making my learning hard and eating through bumpers
    lol HELP!!! Lol
  16. mattyb123
    mattyb123 Member
    gateshead
    use this
    FRONT
    camber 2'50"
    castor 7'30"
    toe 0'05" OUT
    REAR
    camber 1'10"
    toe 0'10" IN
    i have the same setup as you and i use this but with ao48 on the front and i find it great.
  17. magicflying198
    Dereham
    This will be a massive help when setting up the car... Thanks
  18. norbert.r33
    norbert.r33 Member
    Worcester
    any one can send me some setings for r33 or they will be same as s chassis ?
    STREET WITH LITTLE DRIFT
    cheers
  19. wodiz
    wodiz New Member
    I´m running s14 320Whp!
    Federal 595RPM 18"/225 In front
    And chep skid tires in rear : 205-225 17-18"
    DW 4 arm kit (Not geo tension rod)
    Welded Knuckles (No rollcenter correction
    Tie rod spacer
    15mm Longer LCA
    2 Way diff
    Will be used 50% street 50% Track !
    Perhaps trying out from the minimal street use set up ?
  20. Abz-drifter
    Abz-drifter New Member
    ABERDEEN
    Awesome thread thanks very much
