S CHASSIS Alignments
Thread in 'Technical Questions' started by mitto, Mar 15, 2012.
Tags:
  1. mitto
    mitto -NIGHTSPIRT FAMILY-
    - ALBION -
    just this, lots :)
  2. BenRice
    BenRice Well-Known Member
    New Zealand
    Could anyone explain why i'm getting bad camber wear when only running half a degree negative rear camber? Car is an S13 with an S13 subframe and quite low (17" lip 5mm away from metal guard).
    I only have about an inch travel but I've been told it could be due to the toe changing on compression but i dont know if it toes in or out and the interwebs havent been helpful.
    Static toe is set at neutral so which way to go?
  3. CPL
    CPL Member
    Barcelona (Spain)
    Nice thread, with this, i have an idea, but my alignment is so different and the car is so smooth to drive and "easy" to drift.
    On the front i have:
    Camber -2'20"
    Castor 7'
    Toe 0'
    Rear:
    Camber -0'30"
    Toe 0'
    I have poor grip at the rear, go sideways when you push the pedal, hahaha.
    What think about my alignment?
    Greetings!
  4. mike8135
    mike8135 New Member
    Been using street/drift setup for nearly 12 months now on s14a. Love it!!
    Have just widened the rear of the car 30mm on each side. (Overfenders + hubcentric spacers) will I now need to modify the setup to keep it working well?
    Cheers for any help guys!
  5. dan200s14
    dan200s14 Member
    Shepton mallet / wincanton
    Hi mitto and anyone willing to give accurate advice
    I have a s14a 1jzgte engine single turbo @450bhp, 6 point fabricage(just to give an idea of weight,I have steering rack moved 20mm forwards,geomaster front hubs, 25mm hub centric spacers, 18"et30 9.5j, hsd Coilovers wiith 12/8kg springs, no front Arb & Godspeed rear, all alignment arms, 20mm longer lca, extended steering arms!
    I am going for wheel alignement tomorrow and I understand that weight changes the suspension behaviour massively, so I'm hoping you can help!
    Front
    Minimum or -4'20" camber
    7'20" castor
    20" toe out
    Rear
    -30" camber
    10" toe in
    Does this sound about right ?
  6. mitto
    - ALBION -
    Hello everyone asking questions about specific set-ups!
    I'm still getting a huge number of messages on here and on Facebook with regards to alignment. The reason for this thread is to try to help everyone, but I cannot give specific settings on an individual basis. Drift settings are complex and diverse, so if you want me to act as a consultant for you, then please drop me a PM and we can work the cost from there.
    Thanks, Mitto :)
    • Dislike Dislike x 1
  7. racs
    racs Member
    Quick question about this just trying to figure it out! What do u mean by minutes?? Is it set to so many degrees and then turn adjuster (for example) 30 minutes ie half a turn? Or am I completly wrong?? Please explain! ;)
    Cheers Rich
  8. Leno
    Leno Member
    Fleet/Church Crookham
    Bit of a thread revival I know, but I inted on using my car on the street only (so ideally I'm going for a 'fast road' setup) would I be better going for the street/drift setup, or the whiteline setup? They're much the same but little changes can have a big effect!
    Whiteline setup- I'd go for the sport one;
    The car may eventually see the track but I currently have my mx5 for that!
  9. voxhel
    voxhel New Member
    Clarification
    Hi,
    i need some clarification, about the camber, the values have to be negative, yes?
    im using this setup
    MINIMAL STREET / DRIFT USE
    FRONT
    camber 2'50" --> - 2º50'' ???
    castor 7'30"
    toe 0'05" OUT
    REAR
    camber 1'10" --> - 1º10'' ???
    toe 0'10" IN
    RESULT
    Stable but reactive steering
    Strong rear end grip, will push you forwards
    Stable, but needs accurate driver imput
  10. silverzx
    silverzx Member
    Somerset
    Are these suitable with modified hubs/arms/steering arms/tension rods/offset rack spacers?
  11. Leno
    Leno Member
    Yeees, a mate of mine is running these settings with all of the above :)
  12. silverzx
    silverzx Member
    Somerset
    Which settings is he running? I want it very twitchy so that it wants to go out / flick past centre all the time, at the moment I'm having to drive fast, I much preferred my settings i had before which were more twitchy but was only ever done by eye before.. Hah!
  13. Leno
    Leno Member
    The street/drift settings iirc, he did mention a little front toe out helped with the twitchy Ness.. although obviously it's up to you if you fancy playing around with it..
  14. silverzx
    silverzx Member
    Somerset
    Yeah, I need to get it booked in for alignment just want to try get it right before hand so I don't go back again! Think I need more toe out!
  15. Leno
    Leno Member
    Give it a go man and report back, be useful to know!
  16. toyo_
    toyo_ Member
    Spain
    Thanks Mitto!!!!!, from Spain.
  17. ViorelP
    ViorelP New Member
    Sorry if i am off-topic, but i couldn't figure it out.
    What's wrong and why do i have such a positive camber on full-lock? What should i modify?
    I have steering rack spacers for angle and for alignment: -3 camber, 0 toe, 7 caster
    I lose control on full lock. Thank you
  18. CMD 307
    CMD 307 Member
    Peterhead (North east scotland)
    Modified standard hubs??
