For Sale S chassis parts central europe
Thread in 'Parts for sale' started by Gregor, Jul 20, 2020.
Tags:
  1. Gregor
    Gregor Member
    Slovakia Nitra
    Hi guys, im having a clearout of parts for s chassis, the parts are located in Slovakia, im willing to post majority of them, i do have an idea for prices but im willing to take offers.
    Recently broke down a SR20DE out of a s15 spec s, parts have 73k km the parts for sale from this are:
    Starter motor
    Alternator
    Clutch/pressure plate
    Flywheel
    Valve cover
    Distributor
    Engine Block
    Crankshaft
    AC compressor
    Oil pan (the lower sump is smaller than DET upper is same)
    s15 spec s driveshaft
    spec s ecu and wiring loom for the engine
    intake manifold
    throttle body
    camshafts without vtc sprocket (higher lift than DET)
    exhaust manifold with o2 sensor and twin downpipe
    s15 spec s injectors
    I also have stock s13 taillights entire kit with bottom metal piece and 3 lights
    I also have for sale s13 rear arms 3 pairs all except the rear lower control arm so camber arm, toe arm and the third one idk the name of, they are stock arms with nrg suspension bushes.
    i also have for sale an s14 head complete except the cas and rocker cover cams/valves/rocker arms cam caps all there, its also been straigthened 0,10 was taken off to have flat surface.
    I also have a ca18det gearbox wihtout a speed sensor i want 80 euros for this.
    I also have the rear part of a ca18 propshaft that i could sell
    S14 sr20det throttle body
    Again, i do have ideas for the values, willing to take offers, i can post if you cover the costs, heavier items i could post too but its more expensive. Will upload pictures later on.
  2. Gregor
    Gregor Member
    Slovakia Nitra
    crankshaft is out and for sale, s15 spec s oem spec great condition ! 200 euro , block is also great price for block is 150 euro. the DET head with: camshafts, cam gears including vct sprocket, DE rocker cover(needs drilling for coilpack screws) all valves, rocker arms, hydrolifters, guides, sparkplugs, rocker cover gasket and i also have a oem nissan headgasket is 350 euros
    110164004_329432581782102_5868441511591659361_n.
  3. Gregor
    Gregor Member
    Slovakia Nitra
    Also have a oem nissan water pump great condition, oem nissan oil pump needs a new seal, oem nissan timing chain and guides parts have covered only 73k km !
    110168889_750915762343140_3505763271238618701_n.
    109833822_597237044329987_6412068455422639610_n.
    110189169_222540362255147_5649663627632057432_n.
  4. Gregor
    Gregor Member
    Slovakia Nitra
    DE throttle body sold
