S12 snail-paced drift project/daily pride and joy
Thread in 'Project Cars and Builds Threads' started by shilpabhavini, May 20, 2011.
  1. shilpabhavini
    shilpabhavini Member
    W.Midlands
    Yeah had my eye on those but they've been sold so back to the drawing board lol
  2. tooley
    tooley ドリフトキング
    Coventry / Swansea
    Well I won!! Fuck you rounded Mani nut!!! It was no match for my nut extractor bits once the engine was out lol!
    Have now made it so that the Mani will come off in half hour in future lol
    Will fit the intercooler tomorrow !
    Said nut!! Grrr
    Nut tools they cut into rounded nuts! Fucking awesome buy!
    T25 fitted!
  3. sergcab
    sergcab Member
    Ramsey cambs
    them sockets are ace mate. countless number of times they saved me lol
  4. waj786
    waj786 Member
    Bucks
    Looking good..always had a soft spot for s12s
  5. tooley
    tooley ドリフトキング
    Coventry / Swansea
    Final stages now.
  6. Nismo915
    Nismo915 Member
    Stourbridge
    would love to come and see this project, where in west mids are you based?
    i need to fit a intercooler to my S12
  7. shilpabhavini
    W.Midlands
    Based nr coventry mate youre welcome. Will hopefully be at awesomefest. At the moment it's had the t25 and intercooler fitted but is still misfiring and seriously puzzling us.
    Just want my car back :(
  8. richy d
    richy d Active Member
    birmingham
    i'd move that rad away from the slam panel if i were you.looks like it will end up rubbing through.
    did it have the missfire before doing the turbo conversion??i know this will sound obvious but if not then,go back over everything youve removed/moved or adjusted.
    if they are new plug leads,try the old ones back on,if you changed the cambelt,check its timed up correctly etc...
    looks good btw...
    EDIT:is that an icv pipe coming off the manifold thats left disconnected??not sure whether these have a maf or afm,but if that were the case you'd be taking in unmetered air through that pipe,hence crappy running.not a definate fix,but something to look into.
    #28 richy d, Jul 17, 2011
  9. andeep
    andeep Member
    Herts
    Looking good Shilpa!
  10. tooley
    tooley ドリフトキング
    Coventry / Swansea
    Right ive done some trouble shooting, 100% no ignition at no one cylinder!, the car had developed a random missfire where it would drop to 3 cylinders for a few seconds 2 weeks before i did the conversion.
    I have got the new outlet pipe welded see new pic all pipes have been connected. new pic.
    i changed all the spark plugs to ones out of my s15 so i know they work.
    Number 1 is not firing so not sure if its spark, or fuel related. going to check for a spark tomorro grrrrr
  11. shilpabhavini
    W.Midlands
    Riiiight I have been literally too frustrated with not having my car and losing it to a mysterious illness.
    Anyway, it has now had the misfire fixed only to find that the turbo was not viable so had to scope out a new one...
    Word of mouth is amazing, chatting to a few at the Drift-Inc odc sesh on Sunday and Ali (hope it's spelled right) volunteered his t28! Awesome and relief are not good enough to explain how I feel lol
    So now, I'm having a t28 instead if the t25.... I'll keep updates after the fitting this week lol
  12. Cyruz
    Cyruz Sell Out
    Bournemouth/Plymouth
    A friends ratty old S12 had a T28 and fmic and holy crap did it move :D
  13. docwra
    docwra Active Member
    Was the misfire due to the coil not grounding on the wing properly perchance? ;)
  14. tooley
    tooley ドリフトキング
    Coventry / Swansea
    coil was fucked in general, the multimeter showed a voltage drop from 12v to 6v when cranking so it was not amplifying anything.
  15. docwra
    Aye, they seem to be the favourite thing to break on S12', Ive replaced three :wack:
  16. tooley
    tooley ドリフトキング
    Coventry / Swansea
    was a nightmare to track down one! finally got a MSD coil off s13eater for cheap as chips! guy is sound!
  17. tooley
    tooley ドリフトキング
    Coventry / Swansea
    T2 and 25 are fucked! look how much oil was on the 25 just from running it at idle! lol
    need the spiggot for the 28 now so i can connect the cold air intake.
  18. shilpabhavini
    W.Midlands
    This car is doing my nut. Still not working... :(
  19. tooley
    tooley ドリフトキング
    Coventry / Swansea
    60 psi in cylinder 1 missfire found :(.
    Ca18det time :)
  20. Born_Deviant
    Born_Deviant Member
    Norwich
    Soooooooooo want an S12, currently lined up to buy one in a few weeks as long as the soarer sells. Fingers crossed!
