S13 BC Coilover with Geo Master or Wisefab set up
Thread in 'Technical Questions' started by SRRay, Nov 6, 2014.
  1. SRRay
    SRRay mr fussy!
    Ireland
    Just wondering has anybody ran BC coilover with a geomaster or wisefab set up without much modifacation?
    Peoples thoughts /opinions please? :D
  2. PhilMorrison
    PhilMorrison WholeLifeCrisis
    Staff Member
    Birmingham.
    They should fit fine together. Obviously you know that HSD's are better though right? ;)
  3. SRRay
    SRRay mr fussy!
    Ireland
    Of course!:nod:
    Cheers Phil:thumbs: 10% discount still running on all items??
    Money to be got rid of and all that ha!;)
  4. PhilMorrison
    Staff Member
    Birmingham.
    Yep the 10% discount will run until 10:10pm on Friday the 14th :thumbs:
  5. NikH
    NikH Member
    London/Essex
    Im running the BC BR's on my S13 with the Geomaster 2 Knuckles... slight grinding back of the cup of the coilover is required to clear the welds on the knuckles but its not alot of work... The coilover cup holes need to be drilled out to 14mm and you need some 14mm High tensile bolts to go in there. Easy to do
  6. SRRay
    SRRay mr fussy!
    Ireland
    Cool,cheers for that!:thumbs:
  7. Ollie
    Ollie LOOSE!
    London
    To avoid drilling out your coilover holes just go to B&Q and buy a £1.50 section of steel 14mm OD pipe. Its got 13mm Inner diameter, so you cut it down to the width of the mounting point on the hub, tap it in (its perfectly snug) and then use your standard S13 bolts. Easier and cheaper.
