dmax style lights tinted 100posted junyan rear lights modified to look better 50posted center panel need finishing 50posted ca flywheel 20 collected front strut bar sides no bar 15 posted 510cc twin spray top feed injectors 90posted k&n air filter 25posted roll of black heat wrap 10 more added s13... alternator......30 ca cast manifold....10 ca crank sprocket.....10 rocker covers and cam covers .....20 ca sump.....10 ca wood ruff key.....10 fuel rail.......10 ca crank needs regrind big end failer...10 x3 ca pistons and rods ...10 CA Oil cooler standard ...10 ca rear window wiper motor ...10 ca tps ...10 x 2 knock sensors ....10each CA Oil pump..... 40 CA oil pressure switch....10 CA Cold start valve....10 CA Thermostat Housing Pipe ...10 alternator adjustment brackets 10each Water temp sensors dash and ecu for ca ...10 the pair s13 fan stroud good condition 20 ca short braided water line.....25 socketed ecu faulty on my car but maybe ok on facelift? 20 think the socket needs resoldering gearbox plate......20 stereo brackets......10 s14 s14 front bumper......sold S14 cast manifold.....10 S14 auto rad can be used in manual ...10 fog lights for s14 with brackets attached .....10 s14 flywheel ...15 random / universal blitz dual sbc unit and loom only no solinoid ideal spare or if your unit is faulty 50 38mm flange x2 for external wastegate 10 each? 3" exhaust gasket new £2 box off random silcone hose from 43mm upto 63mm in red and blues
