Hey guys, so I had my car pre-mot'd by a garage just to see what it would need to make it sound. They've found a lot more than i had expected so I could do with some help finding some reputable parts which I will hopefully fit myself. The parts I need are: N/S/F Strut Top Bearing O/S/R TCA Adjustable arm inner joint N/S/R Top arm inner bush/bearing Steering rack boot There's also an abs light on which they couldn't tell me much about.. is there any common problems on S13's which could be causing it? A difficulty level for a novice would be appreciated as well
As for ABS, google S13 abs diagnostic, theres an abs ecu that flashes with codes telling you which sensor/s are bad. One on each front hub, one in the rear diff
