Hey guys, so I had my car pre-mot'd by a garage just to see what it would need to make it sound. They've found a lot more than i had expected so I could do with some help finding some reputable parts which I will hopefully fit myself. The parts I need are: N/S/F Strut Top Bearing O/S/R TCA Adjustable arm inner joint N/S/R Top arm inner bush/bearing Steering rack boot There's also an abs light on which they couldn't tell me much about.. is there any common problems on S13's which could be causing it? A difficulty level for a novice would be appreciated as well
Order a set of coilovers and adjustable arms, rip the old suspension out and stick new stuff in. Alot of owners rip the system out as it's pretty pony, do you even have the ABS pump in place anymore?
yeah i have a set of coilovers in already and it already has the arms but there’s lots of play on the joints. will i have to order new arms or will it be able to be repaired? also yes the pump is there. i’m not sure it’s working tho
