- All S13 adjustable arms, rose joints all around, brand new, pair of front and rear LCA, rear toe arms, traction rod and camber arms and front tension rods. 450 - 5 stud front ATTAIN JDM hubs, this is a plug and play mod for S13 owners, you just remove your old 4 stud hub and fit this in the OEM S13 knuckle, no s14 front knuckels, LCA or ball joints are needed, 5 minutes mod. 250 - S13 Radiator cooling panel 1 flat piece fiberglass. 125 - 1 Apexi Power FC ECU and commander (looks like brand new). 350 - Turbo GT3562 for sale, no shaft play 100 - RB25 Alternator + plug if needed 100 - R8 coil pack harness with NGK coils 250 - Greddy intercooler piping kit + clamps and hoses if needed (slightly modified to fit with greddy plenum on s13 chassis) 150 - RB25 MAF 100 - HKS genuine blow off valve, 70 - GKTECH S13/180SX/R32 SUBFRAME ANTI-SQUAT REDUCTION WELD IN KIT 60GBP, brand new. - Taarks Injector Lower Manifold Collars / Adapters (SR20) "S13, 180sx" 25GBP, brand new. - 76mm throttle body, 50GBP, brand new. - SR20DET S13 straightcam intake manifold, comes with TPS and IACV, with connectors. 75 - 300ZX Z32 NA rear knuckles. 100 {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {} {}
