**** l@@@@k s13 stage 3 **** spre-facelift s13 130,000 miles on the clocks engine has covered 65k. 100% rust free shell.. Engine replaced and rebuilt with new main and big ACL bearings, crank checked, cometec Head gasket, valves cleaned, lapped aswel as cambelt and tensioner. New stage 4 6 paddle comp clutch fitted along with reconditioned gearbox at the same time. nissan 200sx full competition spec car ca18det stage 3 engine Stage 3 turbonoz ecu chip Skyline 444cc injectors Z32 afm New roller bearing turbo t28r all braided lines big front mount intercooler oil filter relocator oil cooler full 3.5 inch stainless exhaust Stainless screamer pipe lightend flywheel Stage 4 6 paddle cc clutch 1.2mm head gaskett Battery in car behind seat Dual stage turbo smart boost controller battery cut off outside and inside car turbo timer fully stripped inside front and rear apexi strut braces walbro fuel pump fia bolt in roll cage Sparco deepdish steering wheel 2 omp seats Sabelt 3" harnesses 3 gauges 1 greedy boost gauge 2 swoosh (oil pressure, oil temp) Twin rad fans on switch Strobe light kit fitted yellow lenses pre facelift bumper Front fibreglass vented wider wings uras side skirts uras rear spats Rota gtr drift wheels 17" 9j all round new toyo tr1 tredds Driftworks hsd fully ajustable coilovers front adjustable antiroll bars fully adjustable camber kits apexi adjustable toe arms apexi adjustable camber rear arms apexi adjustable tie rods s14 front arms +10mm wider s14 front steering arms fully 5 stud skyline hub conversion 4 pot skyline brake conversion welded diff fully poly bushed solid subframe mounts New fluids and filters all throughout. Gearbox, engine, powersteering, diff. K n n oil filter, fuel filters etc Will Come with a 12 month ticket no tax for any more info mail or cal 07889 092618 thanks asking £3800 ono may p/x nooo mx5's though sorry [/IMG] [/IMG] [/IMG] [/IMG] [/IMG] [/IMG][/IMG][/IMG] [/IMG] [/IMG]
You got any more pictures of the back end with them spats? I've got the same ones but I haven't fitted them yet as I wern't too sure on them. Not to worry if you haven't, consider it a free bump Glwts
Thanks guys Yeah I will get some more pics up hopefully tomorrow I'll have some time to get some of engine, inside etc etc
oooooh i like.... keep your eye out for a msg, i know your a fair way off leeds but checking to see when ive got time free to get down there....
