I have the following problem since I've bought the car - clutch is slipping on any gear above 1st.Now car is almost stock,did it with the old oem clutch,does it with a brand new valeo oe type clutch.Pressure plate is new. I've adjusted the pedal and master cylinder arm,checked out the rubber line and replaced the slave cylinder.Still slipping.Everything is installed the correct way.Byte/engagement point seems kind of high.Any ideas ?
hey mate check the seal in crack on block back on flywheel maybe loose oil from there it happen again to me in hunday atos daily car i have some years ago
Nope,no leaks.That was the first thing I thought too. Honestly,no.Machinists are real hard to deal with where I live(old + a**holes),plus it was actually pretty clean.I've never did this procedure on other cars I had and everything worked fine,no slipping/vibrations whatsoever.
