s14 rear brakes - bigger shields?
Thread in 'Technical Questions' started by Clu3X, Jun 12, 2010.
  1. Clu3X
    Clu3X Member
    hi,
    i was thinking about maybe it is possible to put bigger rotors on rear in s14? using stock caliper? maybe someone try this ? or know from what car is possible to take similiar rotor but bigger? Like 280? or more?
    thanks for info
  2. diamondsink
    diamondsink Kyouto Drift
    300zx, r33 skyline, r34 skyline
  3. Clu3X
    Clu3X Member
    with skyline rear disc problem is thickness.
    Stock s14 disc have 8mm
    Model Diameter Thickness Center hole height S14 SR20DE/DET 258mm 9mm 68mm 47mm Skyline R32-R34 297mm 18mm 68mm 63mm
    With skyline thickness is impossible to put new brake pads.
    Other options?
  4. al.
    al. actually dom joly
    yeah, put the hub, caliper, and cables from an r33 or z32. which has the added benefit of having a handbrake that actually works
  5. Dan H
    Dan H Member
    How about spacing out the caliper and using S12 rear discs.
    The sizes are:
    Thickness : 10mm
    Diameter : 290mm
    Hub hole dia : 68mm
    Height : 47mm
    You would need to redrill them to 5 stud though.
  6. Clu3X
    Clu3X Member
    In this moment i have more important things to change then calipers ( i want later change them for skyline ones) , because my rear disc are dying i need to replace it fast.
    S12 option looks good, i found one auction on ebay with them but they write that:
    Centering diameter is 47 ?
    REAR BREMBO BRAKE DISCS NISSAN SILVIA 1.8 TURBO S12 84- on eBay (end time 24-Jun-10 13:38:22 BST)
  7. diamondsink
    Dan at DB power does lots of upgrade stuff using the standard calipers.
