S14a 1jz overheating issue
Thread in 'Technical Questions' started by Wayski, May 28, 2021.
  1. Wayski
    Wayski New Member
    windsor
    Hi guys as tittle says I have an s14a with a 1jz gte vvti engine
    I have got a koyo ally rad made for a s14a/sr20
    Twin mishimoto electric fans
    Brand new Toyota water pump
    New thermostat
    Any idea as to why it keeps overheating?
    It only overheats on idle really.
    Anything I can buy to help keep temps down?
  2. joelhachiroku
    joelhachiroku Member
    Christchurch new Zealand
    Sounds like the coolant system needs a good bleed
  3. Spawn_CA18
    Spawn_CA18 Member
    Newcastle
    Sounds like airlock,
    Jack the front of the car high as you can ( or until radiator sits higher than the engine), run the engine and keep topping up the radiator with coolant.
    This should help bleeding it.
