S14a part out, hks dog box, kazz diff, wisefab, rota, hsd.....
Thread in 'Parts for sale' started by g7gno, Jan 15, 2017.
  1. g7gno
    g7gno Member
    S14a shell clean tig welded fabricage non rolling dash all panels and glass exhaust lights rear frame front frame bumper bar steering column and rack full loom £1500 sold
    Sr20det build by mnm engineering just had new oem non ground and balanced crank Acl race main and big end bearings new oil pump rotors in October, Wisco pistons, cosworth 1.2 gasket, hks stet 1 in and ex cam, hks rocker stoppers, big wing alloy sump, will include inlet alternator flywheel £1500 sold
    Borgworner efr 6758 on a custom 3mm wall s/s top mount manifold custom 3" down pipe for s14, this set up made 279whp at 0.7 bar and 323whp at 1 bar on the above engine there is zero play on the shaft it still like new comes with turbo blanket as well, £1100
    Hks 6 speed dog box dogleg, bought from Paul at jdm gargae was removed from his personal onevia, bought in September 16 and only dun 2 events come with all you need to put it in a s14 drive shaft tunnel mount also oil catch can and some pipe £3500
    Sr20det compleat low comp on no 4 £500 maybe sold
    Z32 gearbox with spacer plate front prop and selector £500 sold
    Nistune type 4 in a 14a ecu nats removed £200 sold
    Oem ecu with nats. £30 sold
    Nismo 770cc new in September £300 sold
    Nismo 550cc £150 sold
    Z32 maf with plug £100 sold
    Z32 maf with plug, modified so no bolts or adapters £100 sold
    Competition clutch stage 4 plenty life plate and disc £100
    Garret 2871r has play still made boost before removed £100 sold
    Wisefab front end with Ackerman kit and spare rose joint ends and top mounts £600 sold
    R33 front calipers and large ebc grooved disc conversion and caliper brackets project mu pads new discs and and in September only been out 2 events £300
    Z32 rear calipers with pads and spare pads like new can supply discs but would benefit new ones £200 sold
    Driftworks rear 3 arms kit new start of last year £200 sold
    Kazz 2 way diff 4.1 in 14 case with skyline 5 bolt inputs £250 sold
    Skyline diff 4.3 welded with 5 bolt inputs £200 sold
    Skyline 5 bolt shafts pair £100 sold
    Corbeau revaluation Kevlar £200 keeping
    Bride low max £100 sold
    Bride seat rail drivers side £100 sold
    Carbon covers £50 sold
    Rota gtrd 18x9.5 et12 purple 4 off £500
    Rota gtrd 18x9.5 et12 and et20! I think 2gold 2 purple £500
    Rota torque 17x9.5 et12 bronze 2 of £250 keeping
    Cosmis txt-206r 18x9.5 et10 gold 2of £350
    Hks boost gauge £30 sold
    Hks oil p gauge £30 sold
    Hks water t gauge £30 sold
    Hks tacho £30 sold
    Innovate lc2 compleat with recent new Bosch o2 £100 sold
    Greddy profec b compleat £80 sold
    Hsd monopros £300 sold
    Spitfire coils compleat £150 sold
    Spitfire coils compleat 1 coil faulty kept as spare 3 coils and balest and loom £100 sold
    D1 fuel pressure reg with gauge £40 sold
    Reworked Walbro 340 pump new in September from garage Sr £40 sold
    Blitz bov £30
    New wisefab tie roads still in wrapping 2 of kept as spare £50
    Will be more items, all parts are still on car and will be striped over the next week or 2 so any parts you need let me know and I'll do my best to get them off first as of photos I'm not uploading photos of every part if u need photos call me and I'll send you photos 07707181568
    Location is Fraserburgh north of Aberdeen post can be arranged at cost
    Sent from my iPad using Tapatalk
    #1 g7gno, Jan 15, 2017
  2. ljg94
    ljg94 New Member
    Hi mate I'm interested in that 2871r where abouts are you based?
    Sent from my SM-G935F using Tapatalk
  3. g7gno
    g7gno Member
    Sorry just updated it Fraserburgh
    Sent from my E6653 using Tapatalk
  4. driftasx
    driftasx Member
    Pics of the bride seat please.
    Very interested.
    Can pay now if it's what I want
  5. viz
    viz New Member
    Hi bud, im after gauges, profec and innovate lc2, please send me pm or contact via email - vilius.zilinskas@gmail.com. Thanks.
  6. Darek
    Darek Member
    I will take wisefab kit. Text you
  7. Kingk
    Kingk Member
    Text you
  8. g7gno
    g7gno Member
    All replied I think
  9. blackbullet777
    No way bro!!! [emoji24][emoji24][emoji24] GLWS
  10. TwoSocks
    TwoSocks New Member
    Ill take the:
    Hks boost gauge £30
    Hks oil p gauge £30
    Where are you based?
    52mm or 60mm?
    And do they come with the senders?
  11. g7gno
    g7gno Member
    Need to built e30 can't have both unfortunately
  12. g7gno
    g7gno Member
    Oil p might be sold
    And yeah comes with fittings and so on, 52mm I believe
    North Aberdeen
    Cheers
  13. TwoSocks
    TwoSocks New Member
    Fair enough mate will you post?
    Ill take the boost gauge then
  14. g7gno
    g7gno Member
    Yeah sure give me a txt on 07707181568
  15. TwoSocks
    TwoSocks New Member
    Dropped you a text mate
  16. sukhy96
    sukhy96 Member
    Pics of low max ? if not sold. thanks.
  17. g7gno
    g7gno Member
    Sold sorry
  18. Dangan
    Dangan Member
    message sent
  19. g7gno
    g7gno Member
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  20. ludi
    ludi Active Member
    Clear your inbox. :)
    Best Regards, ludi
