S15 front wheels fitment problem
Thread in 'Technical Questions' started by hotrod, Feb 17, 2019.
  1. hotrod
    hotrod Member
    Italy
    Hi guys, I'm trying to finish my s15 and I've big problem fitting the front wheels! I've put 40mm origin fender, 3.5 camber, almost 0 toe and like 7.3 caster. Dw coilover and all the driftworks arms plus tein tie rod and rod end, 9-18 with 215 40 18. The wheels hit in a bad way the frint of the fender where it match the bumper, a lot more on the left side than yth right. Car didn't has accident or any damage in the frint. Any tips? How can you make it turnable without change the height of the car? @Starkey ?
    Dkf0L4z.
  2. tomsheen
    tomsheen Active Member
    Ireland
    One of the arms must be backwards that’s pushed way too forward
  3. hotrod
    hotrod Member
    Italy
    I don't think, damn it will be a very stupid error, will check anyways, fact is that if I go down with caster I start hit on the rear wheels wheel .. there's people lower than me,why mine touch so bad?
    y9Uy5AO.
  4. BenRice
    BenRice Well-Known Member
    New Zealand
    Take a photo of how you've installed your castor arms
  5. Moejorrison
    Moejorrison Member
    Bristol
    lots of castor angle makes this happen, also just run more camber
  6. hotrod
    hotrod Member
    Italy
    Here are some pics of the arms and coilover
    yJpGHrv.
    97Rk1VT.
    mUgKh1s.
  7. BenRice
    New Zealand
    Well the caster arm install looks fine
    Check that you have matching caster arm / tension rod brackets. I believe R33/R34 ones are shorter IIRC and could be causing this issue. They are easy to unbolt and compare side by side. Failing that, take measurements of each bracket and compare
    Next check where the lower control arm mounts to the subframe and look for any signs of damage. Compare left to right, taking pictures helps. Measure from the the LCA mount to forward to the front cross brace.
  8. hotrod
    hotrod Member
    Italy
    IveI did some measure and they look fine, when i did the alignement the 'data' where good anyways. Arms are for s14/15.. holy shit
  9. BenRice
    New Zealand
    Hang on, how many bolts do you have going from the caster arm into the LCA? It looks from you picture only one
    Can you take a picture from under the LCA, and from above looking down on where the swaybar (aka anti-roll bar) and caster arm are mounted
  10. hotrod
    hotrod Member
    Italy
    They have 2 bolt on the lca
    wcy82Al.
    OkFTmRf.
  11. BenRice
    New Zealand
    Do you have the original caster arms there? If you fit those do the wheels fit the same way?
    Does the bonnet line up with the guards and headlights properly?
    Do you have the standard front guards? If so does the wheel sit in the same place?
    It's looking more and more like poor fibreglass guards
  12. hotrod
    hotrod Member
    Italy
    Mh.. yes I've all the original parts, the fender make me think they're kinda shit for sure. maybe I'll try to add some more camber and see if it make any difference.
    I would like to see some other s15 and know how much caster other guys run and how it look
  13. BenRice
    New Zealand
    Adding camber won't make any difference in the slightest
