S50b32 swap exhaust issue
Thread in 'Technical Questions' started by dibs, Mar 10, 2020.
  1. dibs
    dibs Member
    Hi,
    328i coupe shell - swapped s50b32 conversion.
    Once fitted the OEM s50b32 exhaust was 50mm too short at the front where it meets the manifold after the rear section was offered up to the car.
    If I offer the mid section up to the manifold first then the back box doesn't meet up to the end of the centre section. Also by offering up to them first means that the centre section exhaust hangers don't align.
    Checked and double checked everything... Zf 5sp gearbox and medium case diff line up perfect. Gear stick is on the correct position also.
    Has anyone come across this issue? Thanks
