For Sale Seriously high Spec 1995 180SX....
Thread in 'Drift cars for sale' started by sandstorm, Apr 23, 2018.
  1. sandstorm
    sandstorm Member
    ******NO LONGER FOR SALE*****
    Cover.
    I Bought this car pretty much completely standard.
    All modifications to this car have been performed in my ownership to
    create what i believe to be the ultimate s-body Fast road setup.
    It was on the road in ireland before so VRT is not an issue and
    it can easiely go back on irish roads.
    To say this 180 is quick would be an understatement,
    I built it with the intention of going to the nurburgring in it,
    which i have..... Twice! This car has been an epic experience to build and drive
    and at this point I think i ve done pretty much everything I've wanted to do.
    Richard Bradley setup and mapped the engine and has always looked after it.
    He does all the mechanicing on the car.
    The car was completed and finished before ever driving it
    so all parts are the same age.
    There is about 11,000 miles on this car since completion.
    Car has just had a service and checked over by Bradley Motorworks
    and is ready for the summer.
    SHELL:
    1995 180SX with about 100,000KM on the shell.
    MOT till September 2018. The shell is in outstanding condition being a Jap import and shows
    little to no signs of rust anywhere.
    The car has always been dry stored and only comes out in the summer months.
    ENGINE:
    SR20DET Straightcam boosting to 1.6bar making about 420hp.
    HKS264 step 1 cams.
    BC valve springs.
    Valve stem oil seals changed.
    Port and polish work.
    TDP swish area machining on the head.
    Weisco 86.5 9:1 pistons.
    Egale rods.
    1.1mm cosworth gasket.
    Full set of acl race bearings
    ARP head and main studs.
    ARP flywheel bolts.
    New Nissan oil pump and seals.
    Nismo 740cc injectors.
    RamAir Air Filter.
    Precision 5852 turbo Custom ordered with V-Band Mounts.
    Precision 42mm Wastegate.
    6Boost Manifold custom ordered with V-Band Mounts.
    Nismo Engine Mounts.
    Custom Stainless Downpipe, Stainless silenced De-cat,
    Custom Stainless Shotgun exhaust.
    Custom Stainless intercooler hardpipes.
    Link G4+ Extreme ECU.
    Splitfire Coilpacks.
    Iridium Sparkplugs.
    Greddy Profec B Spec-II
    50mm Driftworks Rad.
    Stainless Header tank.
    Stainless Breather tank.
    Carbon Spark Plug Cover.
    Carbon Slam Panel.
    Engine Earth Kit.
    Battery Relocated to the boot in battery box.
    DRIVETRAIN:
    ACT Extreme clutch
    Standard SR20 Gearbox
    Nismo Gearbox Mount
    Nismo GT-Pro 2way diff.
    Skyline 5 bolt half shafts.
    Skyline 5 Stud hubs all round
    New Genuine front Nissan Wheel Bearings
    K-Sport 8 Pot Calipers with new K-Sport Grooved Rotors
    and new EBC Yellowstuff Pads.
    Standard rear calipers with new EBC Grooved Rotors
    and Yellowstuff pads.
    Braided Brake lines front & back.
    ABS Deleted.
    Rays Volk GT7 Split rims 9"x17" et0 all round
    refurbished in gloss black with gold BBS bolts.
    Rays Wheel nuts.
    Yokohama Advan Neovo AD08r tyres all round.
    SUSPENSION:
    HSD Monopro coilovers with topmounts.
    FRONT:
    Hardrace FRONT ADJUSTABLE LOWER CONTROL ARM.
    Hardrace FRONT HIGH ANGLE TENSION ROD.
    Hardrace DROP LINKS.
    Hardrace FRONT LOWER BRACES.
    Whitlline Adjustable front Antiroll bar.
    Cusco Adjustable upper Strutbrace.
    REAR:
    Hardrace REAR ADJUSTABLE LOWER CONTROL ARM.
    Hardrace REAR ADJUSTABLE UPPER CAMBER KIT.
    Hardrace REAR ADJUSTABLE TOE CONTROL ARM.
    Hardrace REAR ADJUSTABLE TRACTION ROD.
    Rear Upper Strutbrace.
    Subframe Polybushed.
    EXTERIOR:
    Factory Topaz Blue. In very good condition.
    THE ARCHES FRONT & REAR ARE COMPLETELY CUSTOM AND ALL METAL!
    Genuine Kouki Type X front bumper (plastic).
    GRAMS Light front splitter.
    Genuine Chuki Side skirts (plastic).
    GRAMS Light Skirt extensions.
    Genuine Chuki Rear bumper (plastic).
    Custom LED sidelight and Indicator Lens, Tinted.
    Raybrig Headlights.
    Lazy eye kit.
    INTERIOR:
    Nardi Steering Wheel
    Nismo Gear Stick
    Recaro Evo 9 Seats with Alacantra centers and nappa bolsters.
    Genuine Bride Seat rails
    Clarion Headunit with Bluetooth, USB, DAB radio, AM/FM.
    New Speakers all round.
    Pillar Mounted Stack Boost Gauge.
    180sx Floor Mats.
    USB Charging point in glovebox.
    The car can be viewed anytime in north monaghan by appointment.
    I am very well aware of the rareity and standard of the parts on this car
    and therefore im firm on the price. If you think its too dear,
    then try and build one to this spec and see how much you spend.
    20180420_183346. 20180420_183253. 20180420_183247. 20180423_133655. 20180423_133704. 20180423_133720. 20180423_133748. 20180423_133828. 20180423_133822. 20180423_133855. 20180423_133909. 20180418_144027.
    underbody L.
    underbodyR.
    Boot bare.
    #1 sandstorm, Apr 23, 2018
  2. sandstorm
    sandstorm Member
    • Dislike Dislike x 1
  3. sandstorm
    sandstorm Member
  4. sandstorm
    sandstorm Member
    At a time when Standard 18sx's are making £10,000 with 20 year old suspensions, bushings, turbos and engines in them
    this is a proper bargain and literally a new car having only been on the road with this spec from the summer of 2015.
    Every mechanical part was fitted new out of the box not to mention the rareity of the wheels on their own.
    get yourself a bargain and a dream 180sx for £15,000!!
  5. chrisyboi
    chrisyboi Member
    A standard one sells for a half decent price because it hasn’t been fucked around with. And that’s even if they are selling for 10k?
    Yours looks nice and well specc’d but the reality is modifications are subjective and will limit your market.
    For me, I don’t really like your arches, which are metal and would basically mean overs to sort. The wheels are abit “meh” for me, I’d probably change them if I bought it. And if end up changing the seats to.
    So that’s 3 big things that you think raise the value of your car, and to the right person they probably would. But in my eyes I see them as negatives, and would be costly to get how I wanted the car to look.
    Your car does look like time and effort has gone into it, and I’m sure the right person will come along with 15k. B
  6. sandstorm
    sandstorm Member
    Thanks for the input dude...Cant say i agree with ya but each to their own i guess.
    But imo this car is waay more than just some seats and arches.
    When building it i wanted to widen the track as much as possible to increase stability at speed and therefore
    a very low offset and wide wheel was required. I dont believe in FRP overfenders for road cars as they look tatty over time
    and the decision was made to make custom arches to fit the extended track.
    As regards the value of it, I firmly place that in the Engine, ECU, Drivetrain, suspension and braking system, Its bullitproof! Then I'd put value in the custom rust free shell.
    Everything about this car was implemented to make it faster and more stable.
    Its one thing to slap on an S15 turbo and call your car 400hp, Its another to actually create a true 400hp+ car
    that can not only put the power into the ground but have the suspension and braking system to cope with it too.
    #6 sandstorm, Jun 2, 2018
  7. chrisyboi
    chrisyboi Member
    I wasn’t having a dig at your car mate and sorry if I seemed like that. I understand the quality of the parts and even things like the arches I can appreciate the work that’s gone into them.
    I was trying to make a point that it could be a struggle to find the right person who see’s it as perfect in their eyes.
  8. sandstorm
    sandstorm Member
    Haha lol never thought that dude..
    But text never conveys tone very well..
    Yeah I deffo realise it will never be to everyone's taste but sure that's cars for ya..
    But for the person that wants a race spec car that is still comfortable to drive on the road, this should tick a lot of boxes..
    Really and truly I'm only selling to gather funds for a house build and don't really mind if it doesn't sell, I'll happily put her in storage if it doesn't sell by the end of the summer.
  9. Bladerider
    Bladerider Ajudged scoundrel !!
    Decent spec car mate,
    And I understand your pain - my SR20 cost more to build than you're asking for your whole car, yet people wouldn't even give 5k for it when I was thinking of selling lol
    Unfortunately most of the people on here are cheapskate morons who dont do anything properly or understand what it costs to actually build something to support the power and use they read about on their favourite drivers facebook page !! Only 10% at best have the first fucking clue and hopefully one of them will fancy this car as it would make a nice road car Im sure - obviously theres stuff thats personal and we'd all change (dont know if I'd want Ksports myself for example, but appreciate they are a decent spec for their cost).
    Good luck with the sale, I expect this will end up in Scandinavia
    J.
  10. sandstorm
    sandstorm Member
    Ah thats always gonna be the case when youre trying to sell anything expensive..
    Hopefully i can find a buyer who appreciates whats on offer.
    Somethin that you can jump into and nip down to the shops for a pint of milk without having to worry about speed ramps or bad roads shaking youre spinal column apart but is also capable of blitzing a 9min lap around the Nurburgring.
    Race car level adjustability with road car level reliability, style and comfort.
    Or stick in a cage, some competition seats and a hydro and you have a pro spec drift car!
    #10 sandstorm, Jun 4, 2018
  11. sandstorm
    sandstorm Member
  12. willg180
    willg180 Member
    It always baffles me just how many people don't comprehend the cost of building a car like this, it's an absolute bargain! I bought a built car after spending thousand building two previous, knew it was a good deal but when I itemised just the parts for the insurance it was staggering how much money you safe. Yes I carried on spending and making it my own but when is car like this ever finished?!
    I love this car and I wish you GLWS but I hope you get to keep it. My biggest car regret was selling my 180 but I was lucky enough to re-acquired it in the same state 9 years later, and if I hadn't got it back I'd be knocking on your door with £15k in my hand.
    • Informative Informative x 1
  13. sandstorm
    sandstorm Member
    HA! too true buddy, its pretty much half of what i spent building it.... but thats always gonna be the case with cars like this..
    Hopefully i find the right person who appreciates whats on offer and wants a well speced road track s body..
    Glad to hear you got yours back again!
  14. sandstorm
    sandstorm Member
  15. sandstorm
    sandstorm Member
  16. sandstorm
    sandstorm Member
    bump...
    deaycent offers considered...
  17. sandstorm
    sandstorm Member
    bump!!
    Price Reduced £14,000
  18. sandstorm
    sandstorm Member
    BUMP!!!
    Car still here... outstanding example ready to drive!!
  19. kris bobak
    kris bobak New Member
    how much for the car and delivery to the USA?
  20. sandstorm
    sandstorm Member
    i wouldnt have a clue about USA delivery lad.. but id imagine it would be a couple of grand anyway..
