Hi im currently setting up my avcr on my 1jz holset hx35, ive noticed my solenoid has 3 ports with one fitting missing, the two ports are 'com' and 'on' the one thats missing is 'nc' , do i need the NC? Going by google i see people have bottom off WG to the COM an top WG T-pieced into the turbo housing and NC port but no mention of the ON port, so should i just swop the ON fitting into the NC port and then block off the ON port? I have pics but not allowed to upload them which would of explained all this alot clearer, question 2, i have 3 map sensors 1 for avcr,1 for emanage ecu, and 1 factory from the engine, do i really need to plumb all 3 in or can i use one for two jobs, also where do i plumb the map sensors into? thanks any help is appreciated
The ports on the solenoid depend on if it's internal or externally wastegated. What you running? And don't block any ports. If you google avc r guides there's plenty about
