Shes in the Navy Lexus 220djz
Thread in 'Project Cars and Builds Threads' started by robinpipers, Feb 24, 2016.
  1. robinpipers
    robinpipers Member
    Made some cheese out of the crash beam [​IMG]
  2. robinpipers
    robinpipers Member
    Putting back together :)
  3. robinpipers
    robinpipers Member
    Time to make some angle :)
  4. robinpipers
    robinpipers Member
    [​IMG]Shortened my knuckles on the is220 ;)
  5. robinpipers
    robinpipers Member
    Test fitted the knuckles seems good :)
  6. mihaicsv
    mihaicsv Member
    From the pics I'm assuming you shortened the knuckle steering arm.How did you know how much to cut off (dumb I know...)?Is there a way to calculate beforehand ?
    Thanks
  7. robinpipers
    robinpipers Member
    Hey! I've chopped it of and tried to see how much I could cut of. I think mine are 15mm shorter. You can try with the knuckle mounted after cutting and experiment. But I think this is pretty much it.
    The best way to do it is to build some kind of jigg where u can adjust. :) good luck :)
  8. mihaicsv
    mihaicsv Member
    Thanks,really interesting project.
  9. robinpipers
    robinpipers Member
    Thanks :) [​IMG] propshaft made and balanced
  10. robinpipers
    robinpipers Member
    Freshly baked differential
  11. robinpipers
    robinpipers Member
    The driveline is complete :)
  12. robinpipers
    robinpipers Member
    [​IMG] rolled it outside. It's actually pretty much lower with the coils and 16" the it was before. Can't wait to get her up and running now. Just missing a few more parts :)
  13. robinpipers
    robinpipers Member
    Started making seat mounts:)
    Skickat från min SM-G935F via Tapatalk
  14. robinpipers
    robinpipers Member
    Made some seatmounts:)
  15. robinpipers
    robinpipers Member
    Stock diesel in tank pump vs 255 copy. The stock one is actually bigger. 450 walbro is going in :)
  16. counteract
    counteract -o=me
    What else is needed to 'convert' the fuel system to petrol? New lines, filters and a good clean out?
    Mad respect for this, your regular substantial updates make this one of the best current build threads on here imo.
  17. robinpipers
    robinpipers Member
    I hope it's just a clean out. My car will get an e85 system so I expect the filters to need an early change from all the debris and residue in the lines. But apart from that I just hope it holds up. Will change parts when they break.
    What's wierd in the fuelsystem is that the tank got two main lines. Don't know why :)
  18. robinpipers
    robinpipers Member
    Megasquirt arrived. Soon time to make the loom:)
  19. tkddave
    tkddave Member
    Awesome man, love a jz engine!
  20. robinpipers
    robinpipers Member
    No more wiring. Time to wire up the ecu:)
