Shes in the Navy Lexus 220djz
Thread in 'Project Cars and Builds Threads' started by robinpipers, Feb 24, 2016.
  1. robinpipers
    robinpipers Member
    Which diffs does the is220d work with
    Skickat från min SM-G935F via Tapatalk
  2. seanyt
    seanyt New Member
    your diff uses different shafts so you need to use all the newer large diffs.
    facelift ls430
    ls460 / ls600
    3gs
    is300h
    you maybe be able to use the older large diffs but the cv's at the axle end are different with abs trigger rings.
  3. robinpipers
    robinpipers Member
    #103 robinpipers, Aug 7, 2016
  4. robinpipers
    robinpipers Member
    Only intercooler pipes left ;)
  5. David_Cudd
    David_Cudd New Member
    [emoji847]
  6. robinpipers
    robinpipers Member
    Intercooler pipes done. Not the prettiest welds but who got time ... :)
  7. robinpipers
    robinpipers Member
    It's getting there:)
  8. sexyfish
    sexyfish New Member
    looks brilliant mate, love the use of something out of the box
  9. robinpipers
    robinpipers Member
    Almost there :)
  10. sexyfish
    sexyfish New Member
    Hey robin, its because if a diesel engine sucks air or runs dry its a massive problem with the injectors and filters the whole system needs to be cleaned, the two lines lowers the probability of that happening as if one gets properly clogged than hopefully the other remains clear
  11. robinpipers
    robinpipers Member
    Okey:) that explains it :)
  12. robinpipers
    robinpipers Member
  13. David_Cudd
    Great job! Video, please? We all want to hear what it sounds like.
  14. i11matic1795
    i11matic1795 Member
    Jeeez it looks mean with those fat wheels/tyres.
  15. robinpipers
    robinpipers Member
    Thanks :) yeah it runs good now. Will get mapped in Wednesday. Should be ready for gatebil in end of September : ) might take it out and start Street tune it tomorrow :)
    #115 robinpipers, Sep 3, 2016
  16. robinpipers
    robinpipers Member
    #116 robinpipers, Sep 4, 2016
  17. bigdave z20
    bigdave z20 Member
    Awesome job dude! Proper balls needed to run that turbo on a 1J! Love it! What does it drive like?
    Exhaust housing looks large!!!lol
    #117 bigdave z20, Sep 5, 2016
  18. robinpipers
    robinpipers Member
    I don't really know yet. Gearing seems okey but first gear is very much longer compared to the soarer haha :) it's getting tuned Wednesday, so let's c if the engine blows up but hopefully not :)
  19. robinpipers
    robinpipers Member
    Ok gearing is to low. Results with hx50, stock head and bottom, it seemed like the fuel pressure was fluctuating a little. Anyway hx50 with 25cm housing gave me 524 hp 1000 rpm before limiter. Haha. I'm curious what smaller size housings others are using when modifying their hx50.
    Here's the ketchup picture
  20. BenRice
    BenRice Well-Known Member
    I believe there is a 22cm housing for the HX50, but the HX52 uses the HX50 turbine wheel and i believe the turbine housings are interchangable. They use 16cm housings so could be an option for you if you want to shift it down the rev range drastically
