Sierra Estate Cosworth 2WD, LHD, £3,500 ovno
Thread in 'Drift cars for sale' started by cossie_in_estate, Jun 10, 2006.
Tags:
  1. cossie_in_estate
    cossie_in_estate New Member
    I have priced the car very fairly to sell quickly as the parts in the car are worth far in excess of that if broken. If you’re seriously interested, please either email me n.sharpin@sanden-europe.com or call me (Nick) on 07920 126603
    Full Spec. and story of the car posted here as there is a limit on post size in the Driftworks bb.
    frontcornerhigh.
    LHSview.
    For sale is my beloved Cossie Estate. This car started life as a German registered 4x4 Ghia with 2.9i engine that I bought when I moved out to Germany in 2001. It was my everyday car that I had in addition to a Sierra Sapphire Cosworth 2WD for a bit of fun and I loved it. The Sapphire died in a collision with a barrier at the Nuerburgring so I reshelled it into the estate. Fetaures a 280 + bhp engine, RWD, adjustable suspention and welded diff, making it a good base for a drifting car. Also comes with a spare set of 4 steel wheels with winter tyres ideal for practice.
    seats.
    CossieKombiNurburgring2005Small.
    fordmag1.
    fordmag2.
    The reason that I am selling it is that I now need to get on the property ladder. I am looking for £3,500 for it, but am open to offers very close to it. I have priced it very fairly to sell quickly as the parts in the car are worth far in excess of that if broken. Below is the full spec. of the car. If you’re seriously interested, please either email me n.sharpin@sanden-europe.com or call me (Nick) on 07920 126603
    rhsview.
    frontcorner.
    Body
    1989 Ford Sierra Estate 4x4 shell in mercury grey with A/C
    Ford tinted windows
    Electrically heated front & rear screens (with integrated radio antenna)
    Slide & tilt sunroof
    Roof bars
    Rolled wheel arches
    Genuine Ford Cosworth body kit including front bumper, side skirts and rear bumper
    Front fog lights
    Sierra Cosworth 4x4 bonnet with vents
    frontview.
    Interior
    Sierra Cosworth 2WD Recaro front seats in light grey cloth in excellent condition
    Sierra Cosworth 2WD dash clocks (rev counter to 7k rpm, speedo to 170 mph)
    Front electric windows
    Central locking
    Lamp failure warning and door open display
    Centre console with armrest in matching light grey trim
    Aftermarket leather steering wheel
    dash.
    Engine
    2.0 16V YB Turbo from Sierra Cosworth 2WD
    T3 Turbo boosting to 1.5 bar on Sierra Cosworth 2WD exhaust manifold with individual Exhaust Gas Temperature sensors
    Twin 2.5” exhaust system in stainless steel from Power Engineering with single backbox
    Controlled by L8 ECU with 3 bar MAP sensor, PF09 TPS and 4 x Bosch ‘803 injectors running Turbosports Stage 2 chip – see Performance section
    Sierra Cosworth 2WD wiring loom
    Grp. A iginition coil
    Rebuilt 10k miles ago into 205 block with 0.5mm overbore with new crank bearings from Cosworth and gaskets from Cometic
    0.5mm oversize genuine Sierra Cosworth 4x4 pistons from Mahle
    New oil pump
    Grp. A headgasket and std. head bolts
    Grp. Cambelt with new tensioner pullley
    Sierra Cosworth 2WD fuel tank, fuel pump and fuel filter
    Sierra Cosworth 4x4 fuel rail with integrated Fuel Pressure Valve
    Sierra Cosworth 4x4 inlet plenum cover
    Sierra Cosworth 2WD cylinder head with 16 new valves bought from Cosworth
    Ported cylinder head and matched inlet and exhaust manifolds
    Sierra Cosworth 4x4 intercooler
    Sierra Cosworth 2WD airbox with K&N panel filter
    Sierra Cosworth 2WD radiator
    enginebay.
    Transmission
    Std Ford Sierra Cosworth 2WD 9.5” clutch
    Borg Warner T5 5 speed gearbox with shortened gear lever
    Sierra Cosworth 2WD propshaft
    7.5” welded differential with 3.64 ratio
    Sierra Cosworth 2WD driveshafts
    diffandexhaust.
    P4290010.
    Wheels & Tyres
    Ford RS 7 spoke wheels in ‘Softline’ design – 7.5J x 17”
    Goodyear Eagle F1 GS-D3 tyres in 215 45 ZR17 (2 x rear tyres only 1k miles old)
    rearwheel.
    Brakes
    Hydraulically assisted Teves ABS system
    Front: AP Racing 330 x 32mm discs on gold anodised bells. 4 piston Ford callipers with spacers and custom brackets
    Rear: Sierra Cosworth 2WD std. rear single piston callipers with 273mm solid discs
    frontbrakes.
    Suspension
    Front: Koni coil over McPherson struts with under bonnet adjustable damping and height adjustable spring platforms and polyurethane bushes on the top mounts
    Sierra Cosworth 2WD anti-roll bar with polyurethane bushes
    Sierra Cosworth 2WD track control arms with polyurethane bushes and eyes for adjustable compression struts
    Rear: Koni adjustable dampers on Estate semi-trailing arms mounted to Sierra Cosworth 2WD rear beam holding a 7.5” differential
    strut.
    tca.
    Steering
    Sierra Cosworth 2WD LHD steering rack with PAS (2.6 turns lock to lock)
    Sierra Cosworth 2WD tie rods and tie rod ends
    Sierra Cosworth 2WD hubs
    Performance
    Rolling Road measured at 280 bhp @6000 rpm at 1 bar boost, with 320 lb.ft of torque @ 4000 rpm
    ¼ mile measured at Santa Pod at 14.4s @ 100 mph at 1 bar boost
    0 – 60 mph in sub 6s
    Capable of sub 9 minute laps of the Nürburgring Nordschleife
    Magazine appearances
    The car has appeared in the December 2005 edition of Fast Ford magazine and May 2006 editions of both Fast Ford and Performance Ford magazine
    rearview.
    bootopen.
  2. MJG
    MJG Active Member
    good shit! all the best for the sale
  3. Batfink
    Batfink Active Member
    Hiya ForgienRS Batfink off PF here:wave: Great car shame to see it go
  4. cossie_in_estate
    thanks guys. i'm sad to see it go also
  5. Dogs Danglies
    Dogs Danglies Sick Puppy
    Surrrrrweet, bet that surprises a few people at the lights, thats seriously PIMP
  6. Sx Drifter
    Sx Drifter My Island
    not at all pimp :no:
    but stealthy for sure :thumbs:
  7. Dogs Danglies
    I just use PIMP as a byword for anything cool, different, ect, no need to be so pedantic on my ass...
    Like using the word gay, doesn't actually mean something is homosexual...
  8. Jeek™
    Jeek™ Active Member
    oh DAMN! Wish i had the cash to buy this now! Damn my house!
  9. MJG
    MJG Active Member
    yes jeek - damn your house! we could be supertramp brothers :wack:
  10. Bon Bon
    Bon Bon It'll be fine
    Shame you gotta sell it, remember you following us at the nordschleife :)
  11. cossie_in_estate
    that was what got me into drifting and why this now has a welded diff:thumbs:
  12. cossie_in_estate
    now breaking. all parts available, including rear beam with 7.5" welded diff
  13. Jeek™
    Jeek™ Active Member
    :cry: :cry: Thats a bit shit!:cry: :cry:
  14. Mike@TDSW
    Mike@TDSW Active Member
    I have a friend that may want a few bits from you. I will give him a shout.
  15. Mike@TDSW
    What transmission has it got? He has a saff coss but with some random transmission, prop and diff.
    If it is cossie tranny and prop price please? Not interested in welded diff as this is going to be a road car.
    Sorry did just re-read and see this
    "Std Ford Sierra Cosworth 2WD 9.5” clutch
    Sierra Cosworth 2WD driveshafts"
    Prices for all of that, bar diff, independently please.
    #15 Mike@TDSW, Jun 30, 2006
  16. cossie_in_estate
    clutch will be sold with the engine
    t5 gearbox £250
    propshaft £75
    driveshafts £50 for the pair
    thanks.
  17. cossie_in_estate
    Sold in 2006!
