Sil80 to Ps13
Thread in 'Project Cars and Builds Threads' started by danoptiondrift, Dec 9, 2017.
  1. danoptiondrift
    Hi everyone thought I would do a build thread for this one
    So I got a ps shell pretty cheap so I decided to take my sil80 and re shell it into ps as I have always wanted one
    B52B5546-20C2-4995-AE81-81820896D317.
    Right so this is how I got the ps
    B2BD4DBF-6818-440B-B16F-774E692E6182.
    It was a completely stripped shell so I began to strip the sil80 taking the engine box and the subframes and coilovers so I could get this shell rolling so I could get it off to hdf motorsport to have a tubed front end on as the person before me done a lush up of a job on it
    FF87E47F-6153-42DA-87C5-92F46296919E.
    So got it rolling then dropped it off at hdf motorsport
    65B366F6-84AE-49B3-AEB2-67037BD8199C.
    A6376FAB-0544-4AE2-BC40-73B1C56E28E9.
    Hdf motorsport dome an awesome job on my front end next up had to paint it
    6FC51144-1E3A-4122-BEA5-B25E7408F7CF.
    Thanks to dave bastin for letting me use his booth,materials and showing me what to do I managed to paint it myself and it actually came out really nice
    Tomorrow I’m going to do some more bits to it so will hopefully have some more to share with you all
    Thanks for reading all questions welcomed
  2. B-kruse
    B-kruse New Member
    Sweden
    Looks really great so far!
    Check out my build too if you want :)
  3. G535
    G535 Member
    West Germany
    Awesome! Pumped to see where this is going!
  4. danoptiondrift
    Didn’t manage to get anything done on the car today so I done a bit of practice on my Tig Welder
    I’m thinking of running stainless steel boost pipes has anyone done this and suffered with heat?
    Here is a practice piece of stainless
    5C95F182-E4DB-44BF-BBF5-C5EDA23BE433.
  5. shikari_chaos
    shikari_chaos Member
    You should be fine as long as you have connectors to stop the transmission of vibration and engine movement to the intercooler you should be fine, silicone connectors etc.
  6. jbsauce
    jbsauce Member
    Almost a shame to spray that work, would of been sick to just clean coat it haha
  7. danoptiondrift
    I started to prep the inside for paint tomorrow evening and my racing line brake hoses turned up also excellent service from Lewis
    26A9AFC1-5C46-4F2B-BE55-5530C7C6724D.
    D85E548E-1BBD-42A9-9CF9-4525F4FC184A.
  8. danoptiondrift
    Managed to get the inside paint last thanks to dave bastin once again
    This weekend I’m going to start fitting up the brake lines fuel lines and all the other bits ready to go to nispro in January to have the loom and dash done
    5DFFBC94-8D22-41B9-AD71-322EE01F8EA4.
    CD9B91E8-AAF8-4065-952A-4F8D037BD99E.
  9. danoptiondrift
    Don’t some more on this over the last week I managed to get the s15 dash in fit quite well and wasn’t to hard because I’m not using the standard heater system
    E0A11BB6-E827-4993-83B6-A69A397BAE9B.
    This is the heater system
    67BD0E79-1E00-4ACD-BF1F-3354D919A428.
    Also to get the brake lines that I got from racing lines in just waiting on my hydro to get it completely finished
    Fuel lines and swirl pot are also in and p clipped up
    47712BF7-B169-4ACD-A575-F433A4258668.
    3CA45E76-A32D-4EF0-A4F6-54E4FAE44171.
    Fuel tank is also in for good now I gave that a coat of hammerite for protection
    Hopefully I will have the engine and box back in over the next few days
  10. ianlea73
    ianlea73 Well-Known Member
    Bristol
    What is that heater system?
    How do you vary heat & speed?
    Looks really neat.
  11. sugar85
    sugar85 New Member
    Great job mate, i suggest you to run the fuel lines under the car instead of inside
  12. jonnydiscopants
    jonnydiscopants Me lovr you looong time
    The moon
    Fuel lines are fine as long as they are teflon lined, safer in there than underneith
    Looks a tidy build!!?!?
  13. danoptiondrift
    So I have been flat out and haven’t had time to post on here so here is an update
    The car is 99% finished only tidying up of wiring to do
    I will do loads of photos at he end of this post
    Since last time I got the engine and box in made all new boost pipes got everything ready to run so I could send the car to nispro performance for a cartek panel and dash2pro dash
    I tig welded the hydro mount in for my obd handbrake got it all plumped up and was working spot on
    In January the car went to nispro to have the wiring done
    I then managed to get a driftcup season ticket so the car needed to be ready for the (March 11th)
    Car was a little longer than expected at nispro however Walton went above and beyond to get the car ready
    I got the car with a week and a half before driftcup with still a big list of stuff to get done
    Tub the rear arches
    Fit the roll cage
    Fit seats and harness
    Get a kit
    All the body work
    Paint the car
    And a lot of small jobs
    So I got it all ready for the Monday to go to dave Bastin for paint he had already painted my cage and I had got that in
    The car went to dave and he had his work cut out for him the dent took longer the he expected so the Wednesday before driftcup we managed to get it in primer which left us 2 days to finish before driftcup but dave being the fucking man and getting not much sleep we got it done and ready to leave Saturday morning for rockingham
    Saturday driftcup practice
    We had a vacuum hose pop off the actuator 2nd lap that had me worried for a minute or two before I found it but popped it back on and the car was spot on all day
    Sunday driftcup
    Started the day off in practice really well got the line and was loving the car
    Qualifiing came and I put in a good but slightly careful lap to put a score on the bored
    Second lap I went for it a bit more and managed to get 5th so happy with that
    So battles came and it not going to bore you but I battles my way up and got 3rd place overall after a very close battle and omt for 3rd
    Super happy with the result and even more happy the car was spot on all weekend
    0F4A03B5-E079-4310-8CBB-6CCB5B886050.
    CFA05F9A-DC03-40B5-876D-E1C4AFC839FC.
    FCEA495C-E4D0-4E90-B20E-1BA9E6BBF5E5.
    7904A72B-46B4-4144-AC65-E7E82DA16F51.
    9424C305-6DC6-4A6B-AE67-3783E1A3ACBD.
    A70733CE-4550-4D8C-ADEA-977376CD1295.
    E9F57281-E2CC-4165-B65E-7E568FC3391A.
    CC1F99FC-6D63-4A8F-BA41-3A4E182983F6.
    4375FB94-3188-40B7-B65F-598BAF5D77EA.
    4AC57289-96B3-4D64-8F86-43EE927C2AFA.
    7C0E1A6C-EF41-43EA-B252-22582B376A8B.
    D26F66B3-9DB2-4250-8CE9-37CC25F458C0.
    8CC114B2-6E4A-4007-BBD4-584F4124821A.
    7D398396-B226-4C36-91EC-A7709E1E5055.
    BFC44A58-E4FF-4D86-B57E-BE2D9E80B949.
    The only thing I’m not happy with is the front bumper so I will be changing the kit before round 2
  14. Shire Motorsport
    Cirencester
    Looking good mate and a good result in a fresh car
  15. Magic21
    Magic21 Active Member
    liverpool
    Great read. Good looking car
