Single calipers or switch to Dual?
Thread in 'Technical Questions' started by smbbob, Sep 13, 2017.
  1. smbbob
    smbbob New Member
    Hi all!
    Am suffering from a known issue when it comes to drifting. When pulling the E brake and pushing the pedal brake at the same time some sort of pressure is remaining in the rear calipers when i get off the brakes.
    Not sure if you guys can understand but when using both E brake and foot pedal brakes together ( I have NO Power brakes so pedal brakes are pressed VERY hard) when released the rear will still be activated and E Brake leaver is stiff and wont let go unless i pump very hard on the pedal brake.
    Will this be solved in any other way rather then switching to dual calipers in the rear? Having interdependent E brake calipers? If not are there any cons of installing dual Calipers?
    Thanks a lot!
