Skyline r32 4 door rb20det
Thread in 'Drift cars for sale' started by rockingretro, Apr 9, 2015.
  1. rockingretro
    rockingretro New Member
    Skyline R32 4 door RB20DET PRICE DROP
    Make: NISSAN
    Model: R32 SKYLINE 4 DOOR
    Year: 1993 (K reg)
    Mileage: 132k
    Test: May 15
    Price: £4500
    ENGINE:
    RB20DET
    Steel internal turbo
    Apexi air filter
    Cometic 1.3mm metal head gasket
    New valve retainers
    Stainless steel turbo down pipe
    decat
    Nismo R32 GTR exhaust
    Oil filter relocation kit
    Alloy catch can
    FMIC
    Front mount oil cooler
    240bhp dyno print out to prove
    New rear water pipes
    New thermostat
    EXTERIOR:
    Original Gtr front end
    Type m side skirts
    Type m spats
    Projector headlights
    Black vinyl wrap
    WHEELS AND BRAKES
    17” 8j & 9j Impul R1 split rims (with centre nuts, plates and spare bolts)
    Parana spec 2 front tyres, hancook rear (spare capital 195/40/17 tyres for stretch look)
    R33 GTS front calipers
    Grooved and dimpled ebc front discs
    SUSPENSION AND RUNNING GEAR
    HSD mono pro coilovers
    Hardrace hardened rubber adjustable tie rods, traction rods, camber arms
    S13 rear sub frame (no hicas)
    R33 front hubs
    25mm front wheel spacers
    S13 rear hubs
    R33 diff
    Braided clutch line
    INTERIOR:
    Original Nardi steering wheel
    Kenwood headunit, uprated speakers all round
    Hks type 2 turbo timer
    Nismo gear knob
    Strengthened clutch pedal bracket
    Unsure on clutch (feels like a stage 2 item)
    The car has not been used in the last 6 months as haven’t wanted to take it out in the winter, speedo is reading 132k which is a mix of k’s and miles and has had an engine change ( before I purchased the car)
    Has been very well looked after in my ownership including all fluids replaced and the metal gasket fitted always warmed up and cooled down. This is a reliable car and was used as a daily in summer. Bad points: the vinyl wrap has split on a few stress points on the front and also missing the front splitter, headlights need a relay fitting as connections are starting to burn out, front ride height needs adjusting after tyre swap.
    Please call or text 07456974129 for any information or more pictures.
    #1 rockingretro, Apr 9, 2015
  2. rockingretro
    Still sitting here
  3. jay-young
    jay-young Active Member
    Isle of Man
    Does this have a cat in it? Or will it come with one for MOT / other version of the MOT? I'm in the Isle of Man and thats the only thing putting me off. Would it sail through an MOT or some advisories?
    EDIT - what colour under the wrap?!
    #3 jay-young, Apr 21, 2015
  4. DoriDave
    DoriDave ~~Sore-Arse~~
    2 miles from the Pod
    You can get a sports cat from Japspeed for about £130, works great, got one on mine for the MOT, sailed through.
    Nice 4 door BTW
  5. AgitatedTrout
    AgitatedTrout Member
    Fareham
  6. rockingretro
    i,
    UK registered cars on H, J & K registrations - 1st August 92 to 31st July 1995 are only subject to a Cat test if there is an exact match in the Cat emissions database. From 1st August 1995 onwards all cars are subject to a Cat test.
    The MOT regs require the presence of a Cat where it was fitted as standard, but only where the emissions test would lead to a FULL Catalyst test.
    As the car stands it's not running a cat. Car passed with ease last year but with an advisory or a rear left wheel bearing. The car has only done a couple of hundred miles since this test. Also the head light switch is burning out/ tripping when I last Had a looK. There are a couple of redundant switches in the dash which I would plumb the headlights to.
    Colour underneath is Matt olive green ( not done by me) original colour is gun metal grey.
    Thanks DoriDave I like it, be sad to see her go.
  7. jay-young
    Isle of Man
    I'm not in England so the rules differ slightly for the Isle of Man, much like I imagine they do for Ireland. Thanks for the reply, I will have to pass as it's not original under the wrap either.
  8. nissanr34cal
    mundford, norfolk
    i put the engine in this car, under the wrap is nato green, the engine came out of a low km car, about 80k if remember correctly
    - - - Updated - - -
  9. rockingretro
    Oh really I didn't think the rules would change seeing as it's still UK. Ok thanks for the intrest intrest.
    Brill thanks for the info
  10. rockingretro
    ONO need the cash. £4,500
  11. zNicko
    zNicko Member
    When was it imported?
  12. rockingretro
    Couldn't possibly tell you, date of first registration in the UK: 01/09/2002
