Slight misfire on boost
Thread in 'Technical Questions' started by dalespencer, Mar 21, 2015.
  1. dalespencer
    dalespencer Member
    Hi. I have a slight misfire when in I'm on wot and max boost. It's not a massive misfire but I can feel and hear it. I have 2 setting on my avcr, 1.25 bar and 1 bar. The misfire only happens on the high setting and 3rd gear upwards, Could it be caused by a slight boost leak? If it's coil packs I'd of thought it would do it on both settings? It's a sr20det btw. Cheers
  2. Cades
    Cades Member
    Rugby
    I would think on the higher boost setting it would stress the coilpacks more,do you have a spare set you could use to eliminate them?
  3. SteveC200
    SteveC200 Used to drift, now I don't.
    Essex
    Try closing the plug gap a little, it sounds like youre blowing the spark.
