Sloth paced '32 build from NZ
Thread in 'Project Cars and Builds Threads' started by 4ever_sideways, Jul 8, 2012.
  1. 4ever_sideways
    Christchurch, New Zealand
    Well I'm just going to be honest, I'm bored as fuck so I thought I'd make a build thread. I've owned my r32 sedan for nearly three years (bought it as a present to myself when I turned 18 lol), not a lot of progress has been made due to the fact that I'm studying at uni so I don't have much money to put towards it.
    Anyway, it's being built as a drift car but will remain road legal.
    This is what is looked like a few weeks after I bought it, gave it a good clean and it came out pretty good
    At this stage, it had 17x9 drift teks, D2 adjustable suspension, front mount and exhaust.
    Started to fit up GTR front bumper and the car already had the bonnet and grille when I bought it.
    Turned out like this
    Hated the tow bar since day one, so I took it off the proper way.
    There was a bit of surface rust on the bumper support so that got tidied up while I was there.
    More to come, just have to upload the photos
  2. 4ever_sideways
    Fitted my catch can
    removed the rubber intake pipe
    replaced it with this
    I stripped everything from the front seats back, I'm yet to remove the useless wiring but it's on my two page long list of things to do. Gave it a paint after removing the sound proofing too.
    Bought some spare wheels, decided they looked better than the drift teks, so on they went.
    SSR hasemi pro 17x8.5+16
    proceeded to remove the A/C which got out of had and ended up with me cleaning up the entire front of the car
    This little thing caused the most problems as it was in the way of one of the bolts
    Tidied up the bumper support
    gave it a coat of paint after cleaning 20+ years of road grime
    painted my grille the right colour
    Not a bad finish considering it was done with a can
  3. 4ever_sideways
    The spec so far:
    Rb20det, front mount+ piping
    3" mild steel exhaust
    D2 adjustable suspension along with adjustable arms (caster, camber ect)
    GTR bonnet, bumper, grille
    Factory side skirts and end caps
    alloy radiator
    Recaro SPG seat
    GTR front strut brace, mines rear
    There's still plenty to do including fitting these
    Hi-flowed Rb25 turbo
    tial external
    Bosch 044 and custom made surge tank, using braided lines and speedflow fittings
    Tomei 2-way diff and 5x1 axles
    What's left:
    fit turbo and external along with Rb26 injectors.
    install and wire up the fuel system
    266 kelford cams with adjustable gears
    Make new 3" stainless exhaust (using V-band connections)
    electric radiator fan install
    powersteering and oil coolers
    put new suspension bushes in
    fit GTR rear sway bar and ultra racing front
    re wire it (engine loom and body loom) strip useless wires
    seam weld it
    underseal the body
    6 point welded in roll cage to motorsport NZ specs
    tune
    roll the guards more, 15mm spacers
    respray in the same metallic black
    Get LVV certification so that it can be legally driven on NZ roads
    #3 4ever_sideways, Jul 8, 2012
  4. 4ever_sideways
    I plan on hiding of of my fuses like this
    similar roll cage to what has been designed for my car
    Have also built a front facing plenum exactly the same as this one
  5. nissanr34cal
    mundford, norfolk
    Good work so far
  6. gibbo s14
    gibbo s14 the yarco
    great yarmouth
    nice car dude .got to love a 4 door
  7. carlrst
    carlrst Member
    norfolk
    attention to detail here is awsome. looking better in every picture!
    is that internal gate welded up enough??
  8. 4ever_sideways
    Thanks guys. Yeah I believe the gate is welded up pretty good, it was done by the shop who built the turbo.
  9. 4ever_sideways
    No major progress with this, although I've now found all the bits I need.
    Acquired a new box which had been in a friends car. Will swap my broken one out and rebuild it to keep as a spare.
    Was bored, so I painted it
    Also picked up some rear traction arms
    Also got this to keep the power steering fluid from boiling
    Just waiting until my uni exams are over before I install everything.
  10. darksyde
    darksyde New Member
    NEW ZEALAND
    is the gtr bumper one of those fake ones? did it have a good fit?? tidy car, i like... would stay away from cut n shut mani though!! standard setup works just fine
  11. 4ever_sideways
    Nope it's a genuine plastic Nissan one.
    Got some weld on fittings put on today (A job I was ment to do last year)
    You can see where this is going can't you?
  12. 4ever_sideways
    Painted
    So much blue
    Back at home, so I pulled the covers off (first time in 6 months, and it hasn't been driven in a year!)and made a start. I'm going to do the wiring side of things first.
    I'm removing the ABS so the computer and associated **** tonne of wiring. Question is what is the other ecu for?
    Turns out some idiots had a go at my wiring too. This is starting to be like my flatmates S13 again.....
    Plan for this weekend is to bin the ECU's and wires then relocate the battery to the boot.
    Made a list, thought it would only be a page..........
    and yeah that's a light bolted to a piece of cardboard lol
    since I'm tracing back all the hicas and abs wires the carpet has to come up. Took the opportunity to chip off the sound deadening
    Got to be one of the worst jobs.........
    Huge thanks to mum for helping chip this shit off. Nearly done the passenger side, just have to wire bush then give it a coat of paint
    Minimal, progress is minimal.
    Have been rather busy at work this week.
    In a bid to tidy up the engine bay the battery was shifted to the boot. Have not run a cable to the boot as yet as we are still deciding on what size to run.
    Making use of the Garage Stalk3r alloy battery bracket :)
    Finished getting rid of all the abs/hicas wires and got the last of the sound proofing off.
    glad to have this out (there's still more to be removed)
    Took the opportunity to paint the floor black like the boot, painting inside the car is a pain in the ass
    Reinstalled the carpet and ran a new wire from the ecu to trigger the fuel pumps. That's about it for today, tomorrow will consist of running the battery wire from front to back and tiding up the last of the wires.
    Had a change of mind about where the relays were positioned along with the battery. In the interest of safety (keeping the electrics away from the fuel) they were shifted to where the back seat was. Mounted in a Battery box , new terminals, new chunky earth wire and some good cable to run to the front of the car which I got for free from work. Now it's just a case of putting all the wires in a protective casing to make it look all pretty and stuff.
  13. 4ever_sideways
    On another note, I pulled the drivers side guard off, it still had that factory blob of seam sealer holding on to the guard, that's a good sign.
    You can have it any coluor as long as it's black
    As y'all know, I like to paint things. My axles were looking a bit worse for wear and my oil cooler was a terrible silver.
    Bring on Friday so I can start stripping the engine bay ready for a coat of you guessed it............ black
    Got the passenger guard off stripped headlights and wiring loom.
    ABS pump gone
    Not much to say, waiting on other people :( Test mounted my oil cooler
    got some new front brake lines made up. Wasn't too keen on using the hel ones after test fitting them.
    Gave the wheel arches a coat of por15 since I won't be using the inner guards anymore
    Finally got round to painting the engine bay
    Currently reassembling it, maybe it will be done by the end of the month.
    Power steering cooler mounted. Just have to get the lines mounted properly.
    The usual Christmas rush has hit at work so I haven't been spending as much time on this as I should be. 27 days worth of work to do in 7 haha.
    all the broken manifold studs are out, took the opportunity to replace them all.
    Braided brake lines in
  14. 4ever_sideways
    Was on the verge of calling it quits with this yesterday, nothing has gone right. Had gone to the point of filling out a trade me listing but couldn't bring myself to actually list it. I'm still being held up by other people,so I'm just continuing with the little annoying jobs for now.
    Made up all the oil cooler lines, and relocated the filter.
    Started to make up a bracket to support my front mount, just have to pop into work to use the drill press as mine can't drill through that steel
    External welded onto the factory manifold.
    Is there a torque for manifold studs or is it just mo' ****ing tight?
    Also installed the garage stalk3r alloy steering bush.
    Finished my intercooler bracket, solid as **** now. Painted in black of course.
    Have replaced a lot of the bolts in the engine bay with stainless ones
    Swapped over my cam covers, replaced the gaskets at the same time.
    Have only done one, will try to get the other one done when I get back from the gym. Also put some new spark plugs in it.
    re-assembled it, missing the wastegate dump as I'm waiting on a friend to make it for me. Ignore the shitty brake line, new one has since been made.
    Have moved onto the back of the car, trying to get these axle nuts off was a ****.
    it required the use of this pipe as a breaker bar
    Dropped the subframe out an started with the por15. Subframe will be stripped in the coming days wand painted in black, then re-assembled with new arms and tomei diff.
  15. 4ever_sideways
    There ya go, the last three posts will catch you up on what I've done in the last two months lol
  16. Doritofu
    Doritofu Active Member
    NZ
    Car is looking mean dude. Dont give up on this thing, itll turn out tops.
  17. 4ever_sideways
    subframe has been painted and awaiting assembly. Decided to make something to roll it around as my jack doesn't like the carpet and it's a little too heavy to carry once the diff is in.
    mostly back together, awaiting on axle bolts then I'll tighten everything up
  18. jeta11
    jeta11 Member
    hampshire
    Nice work, you have most of the shite jobs done it will time to drive it soon.
  19. Seanie R
    Seanie R Member
    cork,ireland
    lovin the way this build is goin,looking forward to seen it finished!
  20. Prof. Oak
    Prof. Oak New Member
    Auckland, New Zealand
    Nice build, keep up the good work!
    P.S I thought I was the only one who painted their rocker covers blue haha
