Yo dudes, Iv got a Soarer breaking.. Parts listed below.. Pictures will be up soon.. Car details- 1996 JZZ30 Auto - Body work is ropey hence breaking.. Mileage is 71k (still in Kms and showing 114k) Was purchased as a non runner, just needed new ECU as battery had been put on wrong way round, fired first time after new Ecu and fuel. I took a video of the engine running before I removed it. Engine- 71k miles - Comes complete with the following.. Turbos & Downpipe Wiring Loom, ECU, Ignition Amp, Coils, Map Sensor, etc.. Starter Motor, Alternator, Power Steering Pump, etc (No AirCon pump) Soarer Rear/Mid Sump Price: £SOLD MV Auto Transmission The box has undergone an MV Valve Body upgrade.. This makes it shift so much quicker between gears.. I'll upload a quick video we made on the ramp before we stripped the car.. We also have a 'SupraStick' Tiptronic Control System to go with it.. This allows you to map the auto box to shift how you want it to, it also allows for steering wheel buttons(or an alternative trigger) to switch between gears(this Soarer has an Aristo steering wheel with the up/down buttons). Price: £500 GReddy Front Mount Intercooler Kit + Free HKS SSQV Dump Valve(The flange for the dump valve is welded on) Includes all the genuine GReddy HardPipes, Pipe Joiners, Jubilly Clips, and Mounting Brackets.. Price: £400 Enkie Wheels - 17x8 et35 & 17x9 et38 Tires - Front Goodyear Eagle F1 235/45 (5/6mm tread) - Rear Mismatched Budget tires 255/40 (4/5mm tread) Price: £450 Fronts have been given a quick clean, haven't cleaned the rears.. The lip is about 3" front, 4" rear.. GReddy Emanage Blue - £170 HKS Boost Controller - £240 (wasn't fitted so it's completely untested) Theres a handful of other bits I'll add up once they are removed and checked over.. Message me if you're after a specific part.. Collection from Guildford Surrey, I can post parts too..
Supra 4 Pot UK Spec Brake Caliper, Drilled/Grooved Discs(No lip on edge), Red Stuff Pads(6mm life left) Price: £SOLD OEM Viscous LSD Diff A02B - Rare 4.1:1 ratio.. £SOLD New looking Viscous Radiator Fan.. £SOLD
It's actually an Altezza Tiptronic wheel, same as Aristo but doesn't have cruise control stalk.. I'm including this free with the gearbox load of parts... I may have an Aristo wheel somewhere though.. I'll have a look and see what Iv got..
Would you be willing to split the gearbox from, supra stick, MV valve body and steering wheel. I already have an extra gearbox. Which version valve body was it?
